HP EliteDesk 705 G3 SFF A68570 4GB 500GB Windows 10 Pro
Quicklinx: CRS5WS00 Mfr#: 1AJ65AW#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
The HP EliteDesk 705 delivers impressive value with uncompromising performance, security, and manageability. Customize your HP EliteDesk 705 with expandable options that provide an enterprise-class experience to meet virtually any business need.
Fit user needs and the budget
Power your PC with the latest 7th generation AMD Pro A-Series APUs and upgrade your system with up to 64 GB of DDR4 memory, the latest SSD drives, graphics, and HP accessories without breaking the budget.
Security built in
IT efficiency reigns supreme when it’s backed by comprehensive security solutions, including HP BIOSphere with HP Sure Start with Protection of BIOS Configuration, Policy and TPM 2.0
Reliability for the long haul
This work-ready PC is designed with platform stability up to 18 months for a long life cycle. Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G5 testing.
Pure performance and enhanced visual experience
The latest AMD PRO A-Series APUs with Radeon™ graphics deliver desktop performance optimized for diverse digital workloads and dependable daily productivity across your business.
  • Let nothing stand in your way
    Help secure the future of your modern business. Modern PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business.
  • Simplify device management
    Reduce the complexity of administration. HP Client Management Solutions and Dash v1.1 allow easy management of your devices.
  • USB Ports
    Make the most of your portable devices with 10 total USB ports and an optional HP Tri-mode Wireless Charging Pad.
  • Collaboration
    Launch Skype for Business meetings quickly with the optional HP Collaboration Keyboard.
  • Reset the performance curve
    Boot up fast and quickly transition between applications with an optional powerful HP Turbo Drive G2.
  • Multi-monitor, multi-task
    Help increase productivity by up to 35% with support for up to four external Elite Displays.
HP EliteDesk 705 G3 - SFF A6 PRO-8570 3.5 GHz - 4 GB - HDD 500 GB - UK
Personal computer - SFF
AMD A6 PRO-8570 / 3.5 GHz (up to 3.8 GHz, (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R5
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Software Included
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Spare Key, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), HP JumpStart, HP Driver Packs (free download)
38 cm x 33.8 cm x 10 cm
6.6 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Product Form Factor
SFF
Built-in Devices
Solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
AMD A6 PRO-8570
Clock Speed
3.5 GHz
Max Turbo Speed
3.8 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD B350 FCH
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R5
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP USB Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Broadcom BCM5762
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
Slots
4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x8 mode)
4 x USB 2.0 (2 front, 2 rear) (two of them with wake functionality, one of them is fast-charging) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.1 Gen 2
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion sensor
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE, Common Criteria EAL4+, low halogen
Power supply
Power Provided
200 watt
80 PLUS Certification
80 PLUS Platinum
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Software
Sustainability Information
ENERGY STAR Certified
38 cm
33.8 cm
10 cm
6.6 kg
10 °C
35 °C
10 - 90% (non-condensing)
Warranties (1)
CRS5 HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £26.43
Other bundles (2)
CRS5 HPE DisplayPort DVI-D Adapter In Stock £19.88
CRS5 HPE USB to Serial Port Adapter In Stock £13.95
