The HP EliteDesk 705 delivers impressive value with uncompromising performance, security, and manageability.
Fit user needs and the budget
Power your PC with the latest 7th generation AMD Pro A-Series APUs and upgrade your system with up to 64 GB of DDR4 memory, the latest SSD drives, graphics, and HP accessories without breaking the budget.
Security built in
IT efficiency reigns supreme when it’s backed by comprehensive security solutions, including HP BIOSphere with HP Sure Start with Protection of BIOS Configuration, Policy and TPM 2.0
Reliability for the long haul
This work-ready PC is designed with platform stability up to 18 months for a long life cycle. Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G testing.
Pure performance and enhanced visual experience
The latest AMD PRO A-Series APUs with Radeon™ graphics deliver desktop performance optimized for diverse digital workloads and dependable daily productivity across your business.
Let nothing stand in your way
Help secure the future of your modern business. Modern PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business. -
Simplify device management
Reduce the complexity of administration. HP Client Management Solutions and Dash v1.1 allow easy management of your devices. -
USB Ports
Make the most of your portable devices with 10 total USB ports and an optional HP Tri-mode Wireless Charging Pad. -
Collaboration
Launch Skype for Business meetings quickly with the optional HP Collaboration Keyboard. -
Reset the performance curve
Boot up fast and quickly transition between applications with an optional powerful HP Turbo Drive G2. -
Multi-monitor, multi-task
Help increase productivity by up to 35% with support for up to four external Elite Displays.
- HP EliteDesk 705 G3 - SFF - A10 PRO-8770 3.5 GHz - 8 GB - HDD 500 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- AMD A10 PRO-8770 / 3.5 GHz (, up to 3.8 GHz, (Quad-Core)
- Cache Memory
- 2 MB L2 Cache
- Cache Per Processor
- 2 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- AMD Radeon R7
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software Included
- Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Spare Key, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), HP JumpStart
- 38 cm x 33.8 cm x 10 cm
- 6.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Solenoid hood lock
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD A10 PRO-8770
- Clock Speed
- 3.5 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- AMD B350 FCH
Cache Memory
- Installed Size
- L2 Cache - 2 MB
- 2 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R7
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS Studio Sound
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP USB Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Broadcom BCM5762
- Data Link Protocol
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
- Slots
- 4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x8 mode)
- 4 x USB 2.0 (2 front, 2 rear) (two of them with wake functionality, one of them is fast-charging) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.1 Gen 2
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion sensor
- Security Slot Type
- Kensington security slot
- ACPI, RoHS, WEEE, Common Criteria EAL4+, low halogen
- Power supply
- Voltage Required
- Power Provided
- 200 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Software
Sustainability Information
- ENERGY STAR Certified
- 38 cm
- 33.8 cm
- 10 cm
- 6.6 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
