HP EliteDesk 705 G3 DM A109700E 8GB 500GB Windows 10 Pro
Quicklinx: CMXDWS00 Mfr#: Y5H55AW#ABU
Processor Type: A10
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 500GB, 500GB
Storage Type: HDD
  • AMD Radeon R7
  • IEEE 802.11n
  • Bluetooth 4.0
£614.52 ex VAT
£737.42 inc VAT
Get uncompromising performance from the space-saving HP EliteDesk 705 Desktop Mini with powerful security, manageability, and a unique portfolio of accessories to support your enterprise.
Discover the value of the Desktop Mini
Take care of your work and optimize your work space. Get up to 32 GB of DDR4 memory, fast SSD drives, and add useful accessories1 for the small, full featured and powerful HP EliteDesk 705 Desktop Mini without breaking the budget.
Security built in
IT efficiency reigns supreme when it’s backed by comprehensive security solutions, including HP BIOSphere with HP Sure Start with Protection of BIOS Configuration, Policy and TPM 2.0
Bring big power to tight spaces
Utilize innovative mounting, expansion, and security accessory options1 to create the right solution for your workspace. Incorporate an Elite display for the optimal zero footprint solution.
Pure performance and enhanced visual experience
The latest AMD PRO A-Series APUs2 with Radeon™ graphics deliver desktop performance optimized for diverse digital workloads and dependable daily productivity across your business.
  • Discover the value of the Desktop Mini
    Take care of your work and optimize your work space. Get up to 32 GB of DDR4 memory, fast SSD drives, and add useful accessories for the small, full featured and powerful HP EliteDesk 705 Desktop Mini without breaking the budget.
  • Security built in
    IT efficiency reigns supreme when it's backed by comprehensive security solutions including HP Sure Start with Protection of BIOS Configuration and Policy and TPM 2.0.
  • Bring big power to tight spaces
    Utilize innovative mounting, expansion, and security accessory options to create the right solution for your workspace. Incorporate an Elite display for the optimal zero footprint solution.
  • Pure performance and enhanced visual experience
    The latest AMD PRO A-Series APUs with Radeon graphics deliver desktop performance optimized for diverse digital workloads and dependable daily productivity across your business.
HP EliteDesk 705 G3 - mini desktop - A10 PRO-9700E 3 GHz - 8 GB - 500 GB - UK
Personal computer - mini desktop
1 x AMD A10 PRO-9700E / 3 GHz (3.5 GHz) (Quad-Core)
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
8 GB (installed) / 32 GB (max) DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA
Hard Drive
1 x 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R7
Audio Output
Stereo
GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, 802.11ac
Keyboard
OS Provided
17.7 cm x 17.5 cm x 3.4 cm
1.3 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Product Form Factor
Mini desktop
Built-in Devices
Speaker, solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD B300 FCH
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R7
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az, Bluetooth 4.0, IEEE 802.11ac
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2280 (x4 mode)
2 x USB 2.0 , 4 x USB 3.1 Gen 1 (2 front, 2 rear) (one of them is charging) , 1 x VGA , 2 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet)
Vertical stand
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion sensor
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE, Common Criteria EAL4+, low halogen
Power adapter
Nominal Voltage
Power Provided
65 Watt
Efficiency
89%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Spare Key, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), HP JumpStart
ENERGY STAR Certified
17.7 cm
17.5 cm
3.4 cm
1.3 kg
10 °C
35 °C
10 - 90% (non-condensing)
HP EliteDesk 705 G3 DM A109700E 8GB 500GB Windows 10 Pro Bundle deal on HP EliteDesk 705 G3 DM A109700E 8GB 500GB Windows 10 Pro
£713.69
Processor Type: A10
Storage Type: HDD
Processor Model: A10 PRO-9700E
Type: Personal computer
Case Style: Desktop slimline
Optical Storage: None
Brand: HP
Price Range Ex VAT: 500 - 750
