Get uncompromising performance from the space-saving HP EliteDesk 705 Desktop Mini with powerful security, manageability, and a unique portfolio of accessories to support your enterprise.
Discover the value of the Desktop Mini
Take care of your work and optimize your work space. Get up to 32 GB of DDR4 memory, fast SSD drives, and add useful accessories1 for the small, full featured and powerful HP EliteDesk 705 Desktop Mini without breaking the budget.
Security built in
IT efficiency reigns supreme when it’s backed by comprehensive security solutions, including HP BIOSphere with HP Sure Start with Protection of BIOS Configuration, Policy and TPM 2.0
Bring big power to tight spaces
Utilize innovative mounting, expansion, and security accessory options1 to create the right solution for your workspace. Incorporate an Elite display for the optimal zero footprint solution.
Pure performance and enhanced visual experience
The latest AMD PRO A-Series APUs2 with Radeon™ graphics deliver desktop performance optimized for diverse digital workloads and dependable daily productivity across your business.
Let nothing stand in your way
Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business. -
Ready to go the distance
The HP EliteDesk 705 Desktop Mini endured 120,000 hours of the HP Total Test Process and is designed to pass MIL-STD 810G testing. This combined with HP temperature control technology helps provide peace of mind in your work environment. -
Green with envy
Help reduce energy consumption and costs with ENERGY STAR and EPEAT Gold certified available PCs capable of running at just 8W during idle. -
Collaboration
Collaborate clearly with HP Noise Cancellation Software and the optional HP Collaboration Keyboard. -
Reset the performance curve
Boot up fast and quickly transition between applications with an optional powerful HP Turbo Drive G2. -
Simplify device management
Reduce the complexity of administration. HP Client Management Solutions and Dash v1.1 allow easy management of your devices.
- HP EliteDesk 705 G3 - mini desktop - A10 PRO-9700E 3 GHz - 8 GB - HDD 500 GB - UK
- Personal computer - mini desktop
- Localisation
- Processor
- AMD A10 PRO-9700E / 3 GHz (, up to 3.5 GHz, (Quad-Core)
- Cache Memory
- 2 MB L2 Cache
- Cache Per Processor
- 2 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon R7
- Audio Output
- Stereo
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Spare Key, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), HP JumpStart
- 17.7 cm x 17.5 cm x 3.4 cm
- 1.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Mini desktop
- Built-in Devices
- Solenoid hood lock
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD A10 PRO-9700E
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- AMD B300 FCH
Cache Memory
- Installed Size
- L2 Cache - 2 MB
- 2 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R7
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS Studio Sound
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az, Bluetooth 4.0, IEEE 802.11ac
- Bays
- 1 (total) / 0 (free) x internal 2.5"
- Slots
- 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2280 (x4 mode)
- 2 x USB 2.0 , 4 x USB 3.1 Gen 1 (2 front, 2 rear) (one of them is charging) , 1 x VGA , 2 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet)
- Included Accessories
- Vertical stand
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion sensor
- Security Slot Type
- Kensington security slot
- ACPI, RoHS, WEEE, Common Criteria EAL4+, low halogen
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 89%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- 17.7 cm
- 17.5 cm
- 3.4 cm
- 1.3 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
Warranties (2)
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £16.86 |
HP Care Pack Next Business Day HW Support Extended Service Agreement 4 Year On-Site - Desktop Only | In Stock | £25.73 |
Monitors (1)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
Keyboards and Mice (1)
HP Premium Wireless Mouse | In Stock | £38.00 |
Other bundles (5)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HPE DisplayPort DVI-D Adapter | In Stock | £13.23 |
HPE DisplayPort to VGA Adapter | In Stock | £16.40 |
HP Dual Head Keyed Cable Lock | In Stock | £43.00 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
