Get uncompromising performance from the space-saving HP EliteDesk 705 Desktop Mini with powerful security, manageability, and a unique portfolio of accessories to support your enterprise.
Discover the value of the Desktop Mini
Take care of your work and optimize your work space. Get up to 32 GB of DDR4 memory, fast SSD drives, and add useful accessories1 for the small, full featured and powerful HP EliteDesk 705 Desktop Mini without breaking the budget.
Security built in
IT efficiency reigns supreme when it’s backed by comprehensive security solutions, including HP BIOSphere with HP Sure Start with Protection of BIOS Configuration, Policy and TPM 2.0
Bring big power to tight spaces
Utilize innovative mounting, expansion, and security accessory options1 to create the right solution for your workspace. Incorporate an Elite display for the optimal zero footprint solution.
Pure performance and enhanced visual experience
The latest AMD PRO A-Series APUs2 with Radeon™ graphics deliver desktop performance optimized for diverse digital workloads and dependable daily productivity across your business.
Take care of your work and optimize your work space. Get up to 32 GB of DDR4 memory, fast SSD drives, and add useful accessories for the small, full featured and powerful HP EliteDesk 705 Desktop Mini without breaking the budget. -
Security built in
IT efficiency reigns supreme when it's backed by comprehensive security solutions including HP Sure Start with Protection of BIOS Configuration and Policy and TPM 2.0. -
Utilize innovative mounting, expansion, and security accessory options to create the right solution for your workspace. Incorporate an Elite display for the optimal zero footprint solution. -
The latest AMD PRO A-Series APUs with Radeon graphics deliver desktop performance optimized for diverse digital workloads and dependable daily productivity across your business.
- HP EliteDesk 705 G3 - mini desktop - A10 PRO-9700E 3 GHz - 8 GB - 500 GB - UK
- Personal computer - mini desktop
- Localisation
- Processor
- 1 x AMD A10 PRO-9700E / 3 GHz (3.5 GHz) (Quad-Core)
- Cache Memory
- 2 MB L2 Cache
- Cache Per Processor
- 2 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA
- Hard Drive
- 1 x 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon R7
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, 802.11ac
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 17.7 cm x 17.5 cm x 3.4 cm
- 1.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Mini desktop
- Built-in Devices
- Speaker, solenoid hood lock
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD A10 PRO-9700E / 3 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- AMD B300 FCH
Cache Memory
- Installed Size
- L2 Cache - 2 MB
- 2 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R7
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS Studio Sound
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az, Bluetooth 4.0, IEEE 802.11ac
- Bays
- 1 (total) / 0 (free) x internal 2.5"
- Slots
- 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2280 (x4 mode)
- 2 x USB 2.0 , 4 x USB 3.1 Gen 1 (2 front, 2 rear) (one of them is charging) , 1 x VGA , 2 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet)
- Included Accessories
- Vertical stand
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion sensor
- Security Slot Type
- Kensington security slot
- ACPI, RoHS, WEEE, Common Criteria EAL4+, low halogen
- Power adapter
- Nominal Voltage
- Power Provided
- 65 Watt
- Efficiency
- 89%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Spare Key, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), HP JumpStart
- ENERGY STAR Certified
- 17.7 cm
- 17.5 cm
- 3.4 cm
- 1.3 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
Bundle includes:
Microsoft Office Home & Business 2019 Box Pack (Medialess, 1 PC, One Time Purchase) worth £191.49 | in stock |
saving £8.33
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
