HP EliteDesk 705 G3 DM A109700E 8GB 500GB Windows 10 Pro
Quicklinx: CMXDWS00 Mfr#: Y5H55AW#ABU
  • AMD Radeon R7
  • IEEE 802.11n
  • Bluetooth 4.0
Get uncompromising performance from the space-saving HP EliteDesk 705 Desktop Mini with powerful security, manageability, and a unique portfolio of accessories to support your enterprise.
Discover the value of the Desktop Mini
Take care of your work and optimize your work space. Get up to 32 GB of DDR4 memory, fast SSD drives, and add useful accessories1 for the small, full featured and powerful HP EliteDesk 705 Desktop Mini without breaking the budget.
Security built in
IT efficiency reigns supreme when it’s backed by comprehensive security solutions, including HP BIOSphere with HP Sure Start with Protection of BIOS Configuration, Policy and TPM 2.0
Bring big power to tight spaces
Utilize innovative mounting, expansion, and security accessory options1 to create the right solution for your workspace. Incorporate an Elite display for the optimal zero footprint solution.
Pure performance and enhanced visual experience
The latest AMD PRO A-Series APUs2 with Radeon™ graphics deliver desktop performance optimized for diverse digital workloads and dependable daily productivity across your business.
  • Let nothing stand in your way
    Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business.
  • Ready to go the distance
    The HP EliteDesk 705 Desktop Mini endured 120,000 hours of the HP Total Test Process and is designed to pass MIL-STD 810G testing. This combined with HP temperature control technology helps provide peace of mind in your work environment.
  • Green with envy
    Help reduce energy consumption and costs with ENERGY STAR and EPEAT Gold certified available PCs capable of running at just 8W during idle.
  • Collaboration
    Collaborate clearly with HP Noise Cancellation Software and the optional HP Collaboration Keyboard.
  • Reset the performance curve
    Boot up fast and quickly transition between applications with an optional powerful HP Turbo Drive G2.
  • Simplify device management
    Reduce the complexity of administration. HP Client Management Solutions and Dash v1.1 allow easy management of your devices.
HP EliteDesk 705 G3 - mini desktop A10 PRO-9700E 3 GHz - 8 GB - HDD 500 GB - UK
Personal computer - mini desktop
AMD A10 PRO-9700E / 3 GHz (up to 3.5 GHz, (Quad-Core)
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R7
Audio Output
Stereo
1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Spare Key, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), HP JumpStart, HP Driver Packs (free download)
17.7 cm x 17.5 cm x 3.4 cm
1.3 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Product Form Factor
Mini desktop
Built-in Devices
Solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
AMD A10 PRO-9700E
Clock Speed
3 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD B300 FCH
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R7
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az, Bluetooth 4.0, IEEE 802.11ac
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2280 (x4 mode)
2 x USB 2.0 , 4 x USB 3.1 Gen 1 (2 front, 2 rear) (one of them is charging) , 1 x VGA , 2 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet)
Vertical stand
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion sensor
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE, Common Criteria EAL4+, low halogen
Power adapter
Power Provided
65 Watt
Efficiency
89%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
17.7 cm
17.5 cm
3.4 cm
1.3 kg
10 °C
35 °C
10 - 90% (non-condensing)
Warranties (2)
CMXD HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £16.46
CMXD HP Care Pack Next Business Day HW Support Extended Service Agreement 4 Year On-Site - Desktop Only In Stock £24.77
Other bundles (2)
CMXD HPE DisplayPort DVI-D Adapter In Stock £11.55
CMXD HPE DisplayPort to VGA Adapter In Stock £13.38
