HP EliteDesk 705 G2 MT AMD A10-8750 4GB 500GB Windows 10 Pro
Quicklinx: BZ3NWS00 Mfr#: M9B20EA#ABU
  • AMD Radeon R7
  • Microsoft Windows 7 Professional 64-bit Edition
The HP EliteDesk 705 delivers impressive value with high-performance technology, security, and manageability. Customize your HP EliteDesk 705 with expandable options that provide enterprise-class experience to meet virtually any business need.
  • Let nothing stand in your way
    Help secure the future of your modern business. Modern PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business.
  • Simplify device management
    Reduce the complexity of administration. DASH, Windows 10 Pro manageability features, and HP Common Core BIOS help you easily and affordably manage assets.
  • Reliability for the long haul
    Extend your business investments with a long life cycle and platform stability.
  • Multi-monitor, multi-task
    Help increase productivity by up to 35% with support for up to four external Elite Displays.
  • Expand with ease
    Extend the life of your purchase. Using the tool-less chassis this easily upgradable platform features up to four expansion slots, ten ports and multiple connectors to help you meet growing demands.
  • Protect your data
    Help keep data safe and secure with dual storage RAID configurations, TPM and SED hard drives.
HP EliteDesk 705 G2 - micro tower - A10 PRO-8750B 3.6 GHz - 4 GB - HDD 500 GB - UK - TAA Compliant
Personal computer - micro tower - administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control, DriveLock, HP BIOS Protection, Setup Password, UEFI BIOS, Master Record Security, Power On Authentication, Pre-Boot Security, 1 USB 2.0 charging port
AMD A10 PRO-8750B / 3.6 GHz (, up to 4 GHz, (Quad-Core)
Cache Memory
4 MB L2 Cache
Cache Per Processor
4 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3L SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
Graphics Controller
AMD Radeon R7
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Software Included
CyberLink Power2Go, HP Recovery Disc Creator, Skype, Windows 7 Professional 64-bit recovery DVD, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, HP Secure Erase, HP Security Manager, Drive Encryption, HP Pixel Sharp
17 cm x 34 cm x 35.5 cm
6.76 kg
TAA Compliant
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Product Form Factor
Micro tower
Built-in Devices
Solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
AMD A10 PRO-8750B
Clock Speed
3.6 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD A78 FCH
Cache Memory
Installed Size
L2 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R7
Video Interfaces
VGA, DisplayPort
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
USB
Ethernet Controller
Broadcom BCM5762
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5" , 1 (total) / 0 (free) x external
Slots
4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x1 - full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height
6 x USB 2.0 (2 front, 4 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control, DriveLock, HP BIOS Protection, Setup Password, UEFI BIOS, Master Record Security, Power On Authentication, Pre-Boot Security, 1 USB 2.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE, Common Criteria EAL4+
TAA Compliant
Power supply
Power Provided
280 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
93%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Software
Sustainability Information
ENERGY STAR Certified
17 cm
34 cm
35.5 cm
6.76 kg
10 °C
35 °C
10 - 90% (non-condensing)
