HP EliteDesk 705 G2 - A series A10 PRO-8750B 3.6 GHz - 8 GB - 128 GB
Quicklinx: CH60WS00 Mfr#: M9B24EA#ABU
  • AMD Radeon R7
  • Microsoft Windows 7 Professional 64-bit Edition
The HP EliteDesk 705 delivers impressive value with high-performance technology, security, and manageability. Customize your HP EliteDesk 705 with expandable options that provide enterprise-class experience to meet virtually any business need.
Pure performance and enhanced visual experience
Unlock the full potential of your PC. The latest AMD PRO A-Series APUs with AMD Radeon™ graphics and HP Pixel Sharp video filtering that produces sharp and color-accurate images and videos, for crystal-clear video conferencing.
Heavy security
IT efficiency reigns supreme when it’s backed by a full portfolio of security solutions, including HP BIOSphere with Sure Start.
Tested to go the distance
Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G testing to help ensure reliability in the most demanding work environments.
  • Let nothing stand in your way
    Help secure the future of your modern business. Modern PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business.
  • Simplify device management
    Reduce the complexity of administration. DASH, Windows 10 Pro manageability features, and HP Common Core BIOS help you easily and affordably manage assets.
  • Reliability for the long haul
    Extend your business investments with a long life cycle and platform stability.
  • Multi-monitor, multi-task
    Help increase productivity by up to 35% with support for up to four external Elite Displays.
  • Expand with ease
    Extend the life of your purchase. Using the tool-less chassis this easily upgradable platform features up to four expansion slots, ten ports and multiple connectors to help you meet growing demands.
  • Protect your data
    Help keep data safe and secure with dual storage RAID configurations, TPM and SED hard drives.
HP EliteDesk 705 G2 - SFF - A10 PRO-8750B 3.6 GHz - 8 GB - SSD 128 GB - TAA Compliant
Personal computer - small form factor - power-on password, serial port I/O control, USB port control, DriveLock, HP BIOS Protection, Setup Password, BIOS Absolute Persistence, UEFI BIOS, Master Record Security, Power On Authentication, Pre-Boot Security, 1 USB 2.0 charging port
AMD A10 PRO-8750B / 3.6 GHz (, up to 4 GHz, (Quad-Core)
Cache Memory
4 MB L2 Cache
Cache Per Processor
4 MB
RAM
8 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 128 GB - SATA 6Gb/s - Self-Encrypting Drive
Optical Storage
DVD SuperMulti
Graphics Controller
AMD Radeon R7
Audio Output
Stereo
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
33.8 cm x 38 cm x 10 cm
6.6 kg
TAA Compliant
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Product Form Factor
Small form factor
Built-in Devices
Solenoid hood lock, SmartCard reader
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
AMD A10 PRO-8750B
Clock Speed
3.6 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD A78 FCH
Cache Memory
Installed Size
L2 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD
1 x 128 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R7
Video Interfaces
VGA, DisplayPort
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Ethernet Controller
Broadcom BCM5762
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external 3.5" , 2 (total) / 2 (free) x internal 3.5" , 1 (total) / 0 (free) x internal 2.5"
Slots
4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
6 x USB 2.0 (2 front, 4 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Power-on password, serial port I/O control, USB port control, DriveLock, HP BIOS Protection, Setup Password, BIOS Absolute Persistence, UEFI BIOS, Master Record Security, Power On Authentication, Pre-Boot Security, 1 USB 2.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, Energy-using Products (EuP) Lot 6, Common Criteria EAL4+
TAA Compliant
Power supply
Power Provided
200 Watt
Efficiency
70%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
33.8 cm
38 cm
10 cm
6.6 kg
10 °C
35 °C
10 - 90% (non-condensing)
