The HP EliteDesk 705 delivers impressive value with high-performance technology, security, and manageability. Customize your HP EliteDesk 705 with expandable options that provide enterprise-class experience to meet virtually any business need.
Pure performance and enhanced visual experience
Unlock the full potential of your PC. The latest AMD PRO A-Series APUs with AMD Radeon™ graphics and HP Pixel Sharp video filtering that produces sharp and color-accurate images and videos, for crystal-clear video conferencing.
Heavy security
IT efficiency reigns supreme when it’s backed by a full portfolio of security solutions, including HP BIOSphere with Sure Start.
Tested to go the distance
Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G testing to help ensure reliability in the most demanding work environments.
Let nothing stand in your way
Help secure the future of your modern business. Modern PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business. -
Simplify device management
Reduce the complexity of administration. DASH, Windows 10 Pro manageability features, and HP Common Core BIOS help you easily and affordably manage assets. -
Reliability for the long haul
Extend your business investments with a long life cycle and platform stability. -
Multi-monitor, multi-task
Help increase productivity by up to 35% with support for up to four external Elite Displays. -
Expand with ease
Extend the life of your purchase. Using the tool-less chassis this easily upgradable platform features up to four expansion slots, ten ports and multiple connectors to help you meet growing demands. -
Protect your data
Help keep data safe and secure with dual storage RAID configurations, TPM and SED hard drives.
- HP EliteDesk 705 G2 - SFF - A10 PRO-8750B 3.6 GHz - 8 GB - SSD 128 GB - TAA Compliant
- Personal computer - small form factor - power-on password, serial port I/O control, USB port control, DriveLock, HP BIOS Protection, Setup Password, BIOS Absolute Persistence, UEFI BIOS, Master Record Security, Power On Authentication, Pre-Boot Security, 1 USB 2.0 charging port
- Localisation
- Processor
- AMD A10 PRO-8750B / 3.6 GHz (, up to 4 GHz, (Quad-Core)
- Cache Memory
- 4 MB L2 Cache
- Cache Per Processor
- 4 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 128 GB - SATA 6Gb/s - Self-Encrypting Drive
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- AMD Radeon R7
- Audio Output
- Stereo
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- 33.8 cm x 38 cm x 10 cm
- 6.6 kg
- TAA Compliant
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Solenoid hood lock, SmartCard reader
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD A10 PRO-8750B
- Clock Speed
- 3.6 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- AMD A78 FCH
Cache Memory
- Installed Size
- L2 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD
- Capacity
- 1 x 128 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R7
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS Studio Sound
- Ethernet Controller
- Broadcom BCM5762
- Data Link Protocol
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external 3.5" , 2 (total) / 2 (free) x internal 3.5" , 1 (total) / 0 (free) x internal 2.5"
- Slots
- 4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
- 6 x USB 2.0 (2 front, 4 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
- Power-on password, serial port I/O control, USB port control, DriveLock, HP BIOS Protection, Setup Password, BIOS Absolute Persistence, UEFI BIOS, Master Record Security, Power On Authentication, Pre-Boot Security, 1 USB 2.0 charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, Energy-using Products (EuP) Lot 6, Common Criteria EAL4+
- TAA Compliant
- Power supply
- Voltage Required
- Power Provided
- 200 Watt
- Efficiency
- 70%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- 33.8 cm
- 38 cm
- 10 cm
- 6.6 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
