The HP EliteDesk 705 delivers impressive value with uncompromising performance, security, and manageability.
Let nothing stand in your way
Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business. -
Ready to go the distance
The HP EliteDesk 705 Desktop Mini endured 120,000 hours of the HP Total Test Process and is designed to pass MIL-STD 810G testing. This combined with HP temperature control technology helps provide peace of mind in your work environment. -
Green with envy
Help reduce energy consumption and costs with ENERGY STAR and EPEAT Gold certified available PCs capable of running at just 8W during idle. -
Collaboration
Collaborate clearly with HP Noise Cancellation Software and the optional HP Collaboration Keyboard. -
Reset the performance curve
Boot up fast and quickly transition between applications with an optional powerful HP Turbo Drive G2. -
Simplify device management
Reduce the complexity of administration. HP Client Management Solutions and Dash v1.1 allow easy management of your devices.
- HP EliteDesk 705 G3 - mini desktop - A12 PRO-8870E 2.9 GHz - 8 GB - SSD 256 GB - UK
- Personal computer - mini desktop
- Localisation
- Processor
- AMD A12 PRO-8870E / 2.9 GHz (, up to 3.8 GHz, (Quad-Core)
- Cache Memory
- 2 MB L2 Cache
- Cache Per Processor
- 2 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express - NVM Express (NVMe), triple-level cell (TLC)
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon R7
- Audio Output
- Stereo
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software Included
- Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Spare Key, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), HP JumpStart
- 17.7 cm x 17.5 cm x 3.4 cm
- 1.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Mini desktop
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD A12 PRO-8870E
- Clock Speed
- 2.9 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- AMD B300 FCH
Cache Memory
- Installed Size
- L2 Cache - 2 MB
- 2 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 0 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 2 x 4 GB
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R7
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS Studio Sound
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Interface (Bus) Type
- PCI Express Mini Card (M.2)
- Ethernet Controller
- Broadcom BCM5762
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 7265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X), dual stream (2x2)
- IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az, Bluetooth 4.0, IEEE 802.11ac
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 2 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2280 (x4 mode)
- 2 x USB 2.0 , 4 x USB 3.1 Gen 1 (2 front, 2 rear) (one of them is charging) , 1 x VGA , 1 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x HDMI , 2 x aerial
- Included Accessories
- HP Desktop Mini Vertical Chassis Stand
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, RoHS, WEEE, Common Criteria EAL4+, low halogen
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 89%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Software
Sustainability Information
- ENERGY STAR Certified
- 17.7 cm
- 17.5 cm
- 3.4 cm
- 1.3 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
Warranties (7)
HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service | In Stock | £33.26 |
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £14.86 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £50.54 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site | In Stock | £33.69 |
HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site | In Stock | £41.17 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site | In Stock | £70.47 |
HP Care Pack Next Business Day HW Support Extended Service Agreement 4 Year On-Site - Desktop Only | In Stock | £25.34 |
Monitors (1)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
Keyboards and Mice (1)
HP Premium Wireless Mouse | In Stock | £38.00 |
Other bundles (4)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HPE DisplayPort to VGA Adapter | In Stock | £16.34 |
HP Dual Head Keyed Cable Lock | In Stock | £43.00 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
