The number of devices you need to make an impact is one. Create and present your vision of success on the HP EliteBook x360 1030 with four use modes to get work done, share content, and enjoy some downtime.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP. -
Take note of it
Take some notes, satisfy your creative side, and navigate through your PC with the new optional HP Rechargeable Active Pen that provides an authentic and inspiring writing and drawing experience and attaches magnetically to your device. -
Keep visual hackers in the dark
Instantly protect against visual hacking with the optional HP Sure View Gen2 integrated privacy screen. At the touch of a button your screen appears unreadable to those around you while you see your content clearly. -
Browse and open attachments confidently
Help protect your PC from websites, attachments, malware, ransomware, and viruses with hardware-enforced security from HP Sure Click. -
Firmware level protection
Protect the firmware that antivirus can't reach! The hardware-enforced self-healing protection offered by HP Sure Start Gen4 automatically recovers the BIOS from malware, rootkits, or corruption. -
Protect critical security processes
Keep your critical applications and processes running even if malware tries to shut them down with self-healing protection.
- HP EliteBook x360 1030 G3 Notebook - 13.3" - Intel Core i7 - 8650U - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (8th Gen) - 8650U / 1.9 GHz, up to 4.2 GHz / 8 MB Cache
- Memory
- 16 GB LPDDR3 (provided memory is soldered)
- Storage
- 512 GB SSD - NVMe, TLC
- Display
- 13.3" WLED touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 4-cell
- Accelerometer, ambient light sensor, magnetometer, gyro sensor, hall sensor
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 30.58 cm x 20.5 cm x 1.58 cm
- 1.25 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year , Limited warranty - software - 90 days
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8650U / 1.9 GHz
- Max Turbo Speed
- 4.2 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC)
Display
- 13.3" - IPS
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 500 cd/m²
- Colour Gamut
- 100% sRGB
- Panel Self Refresh (PSR), Corning Gorilla glass 4, Full HD eDP anti-glare
- Keyboard Name
- HP Premium Collaboration Keyboard
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Camera Features
- IR camera, Windows Hello
- Sound
- Four speakers, 3 multi-array microphone
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, gesture function
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Technology
- 4-cell Lithium Ion
- Capacity
- 56.2 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 5 / 9 / 12 / 15 / 20 V
Connections & Expansion
- Interfaces Details
- 2 x USB-C (supports Thunderbolt) , USB 3.1 Gen 1 (charging) , HDMI , Headphone/microphone combo jack
- Case Material
- Aluminum
- Integrated Options
- Security
- Power-on password, HP DuraKeys, HP Automatic Drive Lock, HP DriveLock, Pre-boot Authentication, Master Boot Record Security, HP Wireless Wakeup, BIOS Update via Network
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter, WACOM AES 2.0 pen
- RoHS, WEEE
- Localization
- 1.25 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £110.93 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £243.92 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site | In Stock | £117.41 |
Other bundles (3)
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.11 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £46.71 |
