Transform your PC to the workstyle of your choice. The stunningly thin and light HP EliteBook x360 1040 helps keep you productive on-the-go. Enjoy the power you want, the security you need, and a brilliant 14-diagonal display.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP. -
Fast performance, connectivity, and responsiveness
Get the exceptional combination of responsive performance, connectivity and speed with a 10th Gen Intel Core processor that lets you launch, create, and connect fast and reliably. -
HP Sure Sense
Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware. -
Designed for where life takes you
Express yourself in almost any light using the ultra-bright outdoor viewable touch display with anti-glare and ambient light sensors. -
Fast and efficient wireless LAN
The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6. -
Automatic recovery from firmware attacks
Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen6 automatically recovers the BIOS from malware, rootkits, or corruption.
- HP EliteBook x360 1040 G7 Notebook - 14" - Intel Core i5 - 10210U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i5 (10th Gen) - 10210U / 1.6 GHz, up to 4.2 GHz / 6 MB Cache
- Memory
- 8 GB LPDDR4 (provided memory is soldered)
- Storage
- 256 GB SSD - NVMe, HP Value
- Display
- 14" WLED touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.1
- Battery
- 4-cell
- Accelerometer, magnetometer, gyro sensor, hall sensor, Time of Flight (ToF)
- Security
- Trusted Platform Module (TPM 1.2) and firmware (TPM 2.0), fingerprint reader
- 31.93 cm x 20.26 cm x 1.66 cm
- 1.32 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Bundled Services
- HP 3 years Next Business Day Onsite Hardware Support for Notebooks (Unit Only)
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i5 (10th Gen) 10210U / 1.6 GHz
- Max Turbo Speed
- 4.2 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache, Intel Thermal Velocity Boost
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR4 SDRAM - non-ECC
- Speed
- 2933 MHz
- Rated Speed
- 2933 MHz
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), HP Value
Display
- 14" - IPS
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 72% NTSC
- Ambient light sensor, Ultra Slim Design, Corning Gorilla glass 5, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR2, 72% NTSC colour gamut
- Keyboard Name
- HP Quiet Keyboard
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- Privacy shutter, hybrid HD/IR camera
- Sound
- Stereo speakers, 4-microphone array
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Spill-resistant, gesture function, glass clickpad
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - PCI Express Mini Card (M.2)
- Miracast, dual stream (2x2), MU-MIMO
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax
- Technology
- 4-cell lithium polymer
- Capacity
- 54 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 5 / 9 / 12 / 15 / 20 V
Connections & Expansion
- Interfaces Details
- 2 x USB-C (supports Thunderbolt 3, DisplayPort 1.2 Alt Mode) (Power Delivery 3.0) , 2 x USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack , HDMI
Software
- Software Included
- HP Support Assistant, HP Hotkey Support, Windows Defender, HP Secure Erase, HP Client Catalog, HP BIOS Config Utility, HP Image Assistant, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP Connection Optimizer, HP Manageability Integration Kit Gen3, HP BIOSphere Gen5, HP Client Security Suite Gen5, HP Cloud Recovery, HP Driver Packs (free download)
- Case Material
- Aluminum
- Integrated Options
- Security
- Power-on password, HP DuraKeys, HP Automatic Drive Lock, HP DriveLock, Pre-boot Authentication, HP Fingerprint Sensor, Master Boot Record Security, HP Wireless Wakeup, HP Sure Click, HP BIOSphere Gen 5, HP Client Security Gen 5, HP Sure Start Gen 5, HP Sure Run Gen 2, HP Sure Recover Gen 2
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- HP 65 Watt nPFC Slim USB-C AC Adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, Common Criteria EAL4+, KC, CIT, low halogen, ICCP
- Localization
- 1.32 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Bundled Services
- 0 °C
- 35 °C
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 240 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 1.043 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 3.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £115.06 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £143.82 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site | In Stock | £122.39 |
Other bundles (3)
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.39 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £46.02 |
