HP EliteBook X360 1020 G2 Core i5-7300U 8GB 256GB SSD 12.5" Windows 10 Pro
Quicklinx: DZ3NWS00 Mfr#: 1EQ21EA#ABU
  • Core i5
  • IEEE 802.11n
Suddenly, everywhere becomes your office with our thinnest and lightest business convertible. From the office to abroad, go wherever work takes you with high-performance specs, industry-leading security, and immersive collaboration.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light HP EliteBook x360.
  • See it clearly
    Pick the right display for the way you work with FHD or UHD touch display.
  • Creativity and collaboration go hand-in-hand
    Enjoy a natural inking experience with the full-size HP Active Pen with App Launch. Share with the touch of a button on the HP Premium Collaboration Keyboard and discuss your work clearly with HP Noise Cancellation.
  • Browse confidently
    Help protect your PC from infected websites, malware, ransomware, and viruses with HP Sure Click-hardware-enforced security for web browsers.
  • Keep visual hackers in the dark
    Instantly protect against visual hacking with the optional HP Sure View integrated privacy screen. At the touch of a button your screen appears unreadable to those around you while you see your content clearly.
  • Self-healing safeguard
    Start with a genuine HP BIOS every time. HP Sure Start Gen3 monitors in-memory BIOS, recovers the platform without user or admin intervention, restores the BIOS to a custom state, and is enterprise ready for centralized management.
HP EliteBook x360 1020 G2 Notebook - 12.5" - Intel Core i5 - 7300U - 8 GB RAM - 256 GB SSD - UK
Notebook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (7th Gen) - 7300U / 2.6 GHz, up to 3.5 GHz / 3 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD - NVMe, TLC
Display
12.5" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Input Device
ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
4-cell - up to 15.5 hours
Hood sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
29 cm x 20.38 cm x 1.39 cm
1.13 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i5 (7th Gen) 7300U / 2.6 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Rated Speed
1866 MHz
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC)
Display
12.5" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
400 cd/m²
Colour Gamut
100% sRGB
BrightView, Ultra Slim Design, Direct Bonding technology, Corning Gorilla glass 4, Full HD ultra wide-viewing angle (UWVA) eDP +PSR
Keyboard Name
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
IR camera, Windows Hello
Sound
Stereo speakers, dual array microphone
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Multi-touch touchpad, ClickPad with gesture support, glass with chemical etched surface
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Miracast, dual stream (2x2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell Lithium Ion
49.28 Wh
Run Time
Up to 15.5 hours
AC Adapter
Output
65 Watt, 5 / 9 / 10 / 12 / 15 / 20 V
Connections & Expansion
Interfaces Details
2 x USB-C 3.1 (supports Thunderbolt 3) , HDMI , Headphone/microphone combo jack
Software
Software Included
HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Password Manager, Windows Defender, HP Velocity, HP Client Catalog, HP Credential Manager, HP BIOS Config Utility, HP 3D DriveGuard, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP System Software Manager, HP Client Security Suite Gen3, HP BIOSphere Gen3, HP JetAdvantage, HP Wireless Wakeup, HP Workwise (free download), HP Management Integration Kit for Microsoft System Center Configuration Manager (free download), HP Sure Click, HP Driver Packs (free download)
Case Material
Aluminum
Integrated Options
Hood sensor
Security
Power-on password, HP DuraKeys, Setup Password, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, adjustable angle (5 positions), HP Fast Charge, MIL-STD-810G tested, HP Sure Start Gen 3
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
USB-C power adapter
Localization
1.13 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
DZ3N HP 90W Smart AC Adapter In Stock £20.45
DZ3N HP 65W Smart AC Adapter In Stock £17.31
Other bundles (3)
DZ3N HP USB-C To VGA Adapter In Stock £22.09
DZ3N HP USB Travel Mouse In Stock £9.39
DZ3N HP USB-C to HDMI 2.0 Adapter In Stock £46.71
