This elegantly designed HP EliteBook is our thinnest business Ultrabook yet. The HP Elitebook Folio 1040 is packed with enterprise-class features like docking capability and premier security to help keep you productive and your data safe.
Carry less. Do more
At just 15.9mm thin, it's our thinnest EliteBook yet. Choose between a 3mm HD or FHD display with all the mobility you'd expect from an Ultrabook.Engage in videoconferences, web-based trainings or streaming videos with smooth audio quality, thanks to DTS Studio Sound and your notebook speakers.Get more done in low light and worry less over minor accidental spills with the backlit spill- resistant keyboard. -
Security you can depend on
HP Sure Start restores productivity and reduces IT help desk calls in the event of a BIOS attack or corruption.Keep productivity high and downtime low with the automated features of HP BIOSphere.Safeguard data, devices and identities with HP's hassle-free Client Security portfolio, including HP Drive Encryption, HP Device Access Manager with Just in Time Authentication, and HP Secure Erase.A fingerprint reader and integrated Smart Card Reader help keep your identity secure. -
Productive powerhouse
Get going in seconds with a solid-state drive. Enjoy the responsiveness of 4th generation Intel Dual-Core processors.Access the Internet and email in more places with optional integrated HP Mobile Broadband featuring 3G and 4G LTE.Use the optional HP UltraSlim Side Docking Station to connect to accessories and printers without the hassle of connecting individual components.Enjoy HP's new multi-gesture touchpad that allows you to use similar gestures as you would on a smart phone or tablet.Power through projects without worrying about recharging with up to 12 hours of battery life. -
Durable and dependable
The HP EliteBook Folio 1040 passes MIL-STD 810G testing for drop, functional shock, vibration, dust, humidity, altitude, high and low temperature, and temperature shock. -
The power of touch
Enjoy the intuitive control of the optional touchscreen that lets you make the most of Windows 8.1.
- HP EliteBook Folio 1040 G1 - 14" - Intel Core i5 - 4300U - vPro - 4 GB RAM - 180 GB SSD - 3G
- Product Type
- Ultrabook
- Operating System
- Win 7 Pro 64-bit
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (4th Gen) - 4300U / 1.9 GHz, up to 2.9 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 180 GB SSD
- Display
- 14" LED backlight HD+ SVA eDP anti-glare 1600 x 900 / HD+
- Graphics
- Intel HD Graphics 4400
- Input Device
- ForcePad
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 3G
- Battery
- 6-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- Platinum
- 33.8 cm x 23.35 cm x 1.59 cm
- 1.49 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - parts and labour - 3 years
- Product Type
- Ultrabook
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4300U / 1.9 GHz
- Max Turbo Speed
- 2.9 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Chipset
- Intel QM87
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 4 GB (provided memory is soldered)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 180 GB SSD M.2 SATA 6Gb/s
Display
- 14" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- Image Aspect Ratio
- 16:9
- HD+ standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, stereo microphone
- Codec
- IDT 92HD91
- High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
- Keyboard, ForcePad
- Volume control, spill-resistant, multi-touch touchpad
Communications
- Wireless
- Bluetooth Class
- Class 2
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Generation
- 3G
- Technology
- GSM, GPRS, EDGE, HSPA+
- Controller
- HP hs3110 - M.2 Card
Navigation
- Receiver
- GPS/A-GPS
- Technology
- 6-cell lithium polymer
- Capacity
- 42 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
Connections & Expansion
- DisplayPort , Headphone/microphone combo jack , Dock , 2 x USB 3.0
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, Device Access Manager, HP Wireless Hotspot (free download), HP Client Security, HP Mobile Connect, HP Secure Erase, Drive Encryption, HP Trust Circles Standard
- Platinum
- Case Material
- Magnesium alloy
- Dockable
- Security
- Charging via USB, HP DuraFinish, HP DuraKeys, HP DisplaySafe, HP SureStart, Full Volume Encryption
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, MIL-STD 810G, WEEE, A-Tick, ICES, KC, CIT
- Localization
- 1.49 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance
- 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
