HP EliteBook Folio 1020 G1 Intel Core M-5Y51 8GB 256GB SSD 12.5" Windows 7 Professional 64-bit
Quicklinx: BHT5WS00 Mfr#: M3N31EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Starting at 1.17 kg. / 2.58 lbs. and 15.7mm /.62 inches thin, the HP EliteBook Folio 1020 is an impressively thin and light business-class notebook. This durable travel companion is fully equipped with HP's leading security and manageability solutions.
  • Remote conferencing made easy
    Collaborate with colleagues around the world using a suite of features including HD web cam, immersive DTS Studio Sound with stereo speakers, dual-array microphone and HP Noise Reduction Software.
  • Create the total package
    Elevate your EliteBook experience by adding useful optional accessories like an ultra-slim docking station, Elite curved display, HP Slim AC Travel Adapter, wireless keyboard, and more.
  • A brilliant view
    See it all with brilliant clarity on a 31,75 cm (12.5") diagonal FHD anti-glare non-touch display or stunning high-resolution QHD touchscreen option.
  • Hassle-free connectivity
    Keep your connection with WiDi, Miracast, and WLAN 802.11ac/Bluetooth 4.0 combo. Plus, easily tether to your phone for mobile broadband on the road.
  • Port support
    Enjoy two USB 3.0 charging ports, a MicroSD expansion slot and HDMI video output.
  • Solid support services
    Take advantage of HP's Elite Support, limited warranty, and Global Series support.
HP EliteBook Folio 1020 G1 - 12.5" - Intel Core M - 5Y71 - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Intel Core M (5th Gen) - 5Y71 / 1.2 GHz, up to 2.9 GHz / 4 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Display
12.5" LED backlight 2560 x 1440 / WQHD
Graphics
Intel HD Graphics 5300
Input Device
ForcePad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, NFC
4-cell - up to 9 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader
31 cm x 21 cm x 1.57 cm
1.27 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
CPU
Intel Core M (5th Gen) 5Y71 / 1.2 GHz
Max Turbo Speed
2.9 GHz
Number of Cores
Dual-Core
Cache
L3 - 4 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1600 MHz
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
12.5"
LCD Backlight Technology
LED backlight
Resolution
2560 x 1440 (WQHD)
Widescreen
Image Aspect Ratio
16:9
QHD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Sound
Stereo speakers, stereo microphone
High Definition Audio, DTS Studio Sound
Input
Keyboard, ForcePad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Half Mini Card
4-cell lithium polymer
36 Wh
Run Time
Up to 9 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Interfaces Details
2 x USB 3.0 , HDMI , Dock , Headphone/microphone combo jack , LAN (on supplied cable) , VGA (on supplied cable)
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Adobe Flash Player, HP Recovery Disc Creator, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP UEFI System Diagnostics, HP BIOSphere, HP Wireless Hotspot, Getting Started guide with Windows 8, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Client Security Manager, Lync Optimized, HP Device Access Manager, HP CIK for Microsoft SCCM (free download), HP Driver Packs (free download)
Case Material
Aluminum, magnesium alloy
Dockable
Security
Noise reduction, fanless, HP 3D DriveGuard, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP BIOS Protection, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security, Intel My WiFi Technology, 2 x USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter, HP Dock Connector to Ethernet/VGA Adapter
ACPI, WHQL, RoHS, WEEE
Localization
1.27 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
