HP EliteBook 850 G7 Intel Core i5 10210U 8GB 256GB 15.6" W10P
Quicklinx: G2GJWS00 Mfr#: 1J6G8EA#ABU
  • Core i5
  • IEEE 802.11n
A collaborative approach to work requires a powerful, secure, and durable laptop that keeps users connected and productive in any setting. Meet the demands of your multi-task, multi-place workday with the lightweight and beautifully designed HP EliteBook 850 G7.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP.
  • Fast performance, connectivity, and responsiveness
    Get the exceptional combination of responsive performance, connectivity and speed with a 10th Gen Intel Core processor that lets you launch, create, and connect fast and reliably.
  • HP Sure Sense
    Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
  • Fast and efficient wireless LAN
    The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6.
  • Automatic recovery from firmware attacks
    Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen6 automatically recovers the BIOS from malware, rootkits, or corruption.
  • Keep your PC's security protections in place
    Stop unwanted changes to security settings and help limit the spread of malware with HP Sure Run Gen3 which identifies, quarantines, and provides reporting on attackers trying to kill processes.
HP EliteBook 850 G7 Notebook - 15.6" - Intel Core i5 - 10210U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (10th Gen) - 10210U / 1.6 GHz, up to 4.2 GHz / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe, HP Value
Display
15.6" WLED HP SureView 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics
Input Device
ClickPad
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac/ax, Bluetooth 5.1
3-cell - up to 24 hours
Ambient light sensor, hall sensor
Security
Trusted Platform Module (TPM 1.2) and firmware (TPM 2.0), fingerprint reader, smart card reader
35.97 cm x 23.38 cm x 1.92 cm
1.7 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i5 (10th Gen) 10210U / 1.6 GHz
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), HP Value
Display
15.6" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
1000 cd/m²
Colour Gamut
72% NTSC
Privacy Technology
HP SureView
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR, 72% NTSC colour gamut
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
Intel UHD Graphics
Camera
Yes - HD
Video Resolutions
720p
Camera Features
Privacy shutter, IR camera
Sound
Stereo speakers, 3 multi-array microphone
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Spill-resistant, multi-touch clickpad, ClickPad with gesture support, precision touchpad
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6 AX 201 - PCI Express Mini Card (M.2)
Dual stream (2x2), MU-MIMO
IEEE 802.11d, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v
3-cell lithium polymer
56 Wh
Run Time
Up to 24 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
Interfaces Details
2 x USB-C 3.1 (supports Thunderbolt 3, DisplayPort 1.2 Alt Mode) , USB 3.1 Gen 1 (charging) , USB 3.1 Gen 1 , HDMI , Headphone/microphone combo jack
Case Material
Aluminum
Integrated Options
Security
Power-on password, Setup Password, Automatic DriveLock, BIOS Absolute Persistence, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, BIOS Update via Network, HP Secure Erase
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
HP 65 Watt Smart nPFC AC Adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, FIPS 140-2, MIL-STD 810G, A-Tick, ICES, Common Criteria EAL4+, FIPS 201, KC, CIT, low halogen, ICCP
Localization
1.7 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
G2GJ HP 65W Smart AC Adapter In Stock £16.89
G2GJ HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £109.31
Warranty Packs (8)
Protect your investment by taking out one of our great value warranty packs
G2GJ HP Care Pack Pick-Up and Return Service Extended Service Agreement 4 Years for EliteBook In Stock £104.74
G2GJ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £88.00
G2GJ HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site In Stock £108.27
G2GJ HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £99.33
G2GJ HP Care Pack Pick-Up and Return Service Extended Service Agreement 5 Years Pick-Up and Return In Stock £138.87
G2GJ HP EPACK 4 Year Onsite NBD+DMR (NB ONLY) In Stock £161.23
G2GJ HP 3 Year Premium Care Notebook service In Stock £141.23
G2GJ HP Carepack 5y Travel NextBusDay Notebook Only SVC In Stock £184.24
Other bundles (3)
G2GJ HP USB-C To VGA Adapter In Stock £22.09
G2GJ HP USB Travel Mouse In Stock £9.11
G2GJ HP USB-C to HDMI 2.0 Adapter In Stock £46.71
