HP EliteBook 845 G7 Ryzen 5 Pro 4650U 8GB 256GB SSD 13.3" Windows 10 Professional 64-bit
Quicklinx: G2DNWS00 Mfr#: 177C7EA#ABU
  • IEEE 802.11n
Ease through your multi-task, multi-place day with the beautifully designed, powerful, highly secure HP EliteBook 845. Created for people on the move, this thin and light laptop helps people confidently connect and stay productive in almost any setting.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP.
  • HP Sure Sense
    Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
  • Fast and efficient wireless LAN
    The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6.
  • Automatic recovery from firmware attacks
    Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen6 automatically recovers the BIOS from malware, rootkits, or corruption.
  • Keep your PC's security protections in place
    Stop unwanted changes to security settings and help limit the spread of malware with HP Sure Run Gen3 which identifies, quarantines, and provides reporting on attackers trying to kill processes.
  • Browse confidently
    Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
HP EliteBook 845 G7 Notebook - 14" - AMD Ryzen 5 Pro - 4650U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
AMD Ryzen 5 Pro 4650U / 2.1 GHz, up to 4 GHz / 8 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe, HP Value
Display
14" WLED 1920 x 1080 / Full HD
Graphics
AMD Radeon R5
Input Device
Pointing stick, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax
3-cell
Ambient light sensor, hall sensor
Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
32.36 cm x 21.47 cm x 1.79 cm
1.33 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
6-core
Cache
L3 - 8 MB
64-bit Computing
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
3200 MHz
Rated Speed
3200 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 PCIe 3.0 x4 - NVM Express (NVMe), HP Value
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Graphics Processor
AMD Radeon R5
Camera
Yes - HD
Video Resolutions
720p
Camera Features
Privacy shutter, IR camera, HP Privacy HD
Sound
Stereo speakers, 3 multi-array microphone
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, pointing stick, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch clickpad, ClickPad with gesture support, precision touchpad, glass clickpad
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6 AX 200 - PCI Express Mini Card (M.2)
Miracast, dual stream (2x2), MU-MIMO
IEEE 802.11d, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v
3-cell Lithium Ion
53 Wh
AC Adapter
Input
Output
45 Watt, 5 / 9 / 12 / 15 / 20 V
Connections & Expansion
Interfaces Details
2 x USB-C 3.1 Gen 2 (Alternate Mode) , USB 3.1 Gen 1 (charging) , USB 3.1 Gen 1 , Headphone/microphone combo jack , HDMI
Software
Software Included
HP Support Assistant, HP Hotkey Support, HP Client Catalog, Absolute Persistence, HP BIOS Config Utility, HP Image Assistant, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP Connection Optimizer, Ivanti Management Suite, HP BIOSphere Gen5, HP Sure Sense, HP Sure Recover Gen3, HP WorkWell, HP Client Security Manager Gen6, HP Sure Run Gen3, HP Sure Start Gen6, HP Driver Packs (free download)
Integrated Options
Security
Power-on password, BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, Master Boot Record Security, HP Sure Run, HP Sure Recover, HP Wireless Wakeup, BIOS Update via Network, HP Sure Start Gen 5
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FIPS 140-2 Level 2, FCC, A-Tick, ICES, Common Criteria EAL4+, KC, CIT, low halogen, ICCP, RED
Localization
1.33 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
G2DN HP 65W Smart AC Adapter In Stock £16.89
G2DN HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £109.31
Warranty Packs (8)
Protect your investment by taking out one of our great value warranty packs
G2DN HP Care Pack Pick-Up and Return Service Extended Service Agreement 4 Years for EliteBook In Stock £104.74
G2DN HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £88.00
G2DN HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site In Stock £108.27
G2DN HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £99.33
G2DN HP Care Pack Pick-Up and Return Service Extended Service Agreement 5 Years Pick-Up and Return In Stock £138.87
G2DN HP EPACK 4 Year Onsite NBD+DMR (NB ONLY) In Stock £161.23
G2DN HP 3 Year Premium Care Notebook service In Stock £141.23
G2DN HP Carepack 5y Travel NextBusDay Notebook Only SVC In Stock £184.24
Other bundles (3)
G2DN HP USB-C To VGA Adapter In Stock £22.09
G2DN HP USB Travel Mouse In Stock £9.11
G2DN HP USB-C to HDMI 2.0 Adapter In Stock £46.71
