HP EliteBook 840 G9 Intel Core i5-1245U 16GB 256GB SSD 14" Windows 11 Professional 64-bit
Quicklinx: H4HHWS00 Mfr#: 6T198EA#ABU
Type: Laptop
Screen Size: 14in
Processor Model: I5-1245U
Operating System: Windows 10 Pro, Windows 10 Pro
Installed Memory: 16GB
  • Core i5
  • IEEE 802.11n
£1,456.28 ex VAT
£1,747.53 inc VAT
Remove barriers to hybrid work with the HP EliteBook 840. This enterprise business laptop brings new conferencing capabilities powered by HP Presence, productivity, and security that is easily managed in hybrid work environments.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP.
  • HP Sure Sense
    Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
  • Fast and efficient wireless LAN
    The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6.
  • Browse confidently
    Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
HP EliteBook 840 G9 Notebook - 14" - Intel Core i5 - 1245U - 16 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro (downgrade from Windows 11 Pro) + Windows 11 Pro Licence - English
Intel Core i5 (12th Gen) - 1245U / 1.2 GHz, up to 4.4 GHz / 12 MB Cache
16 GB DDR5 (1 x 16 GB)
Storage
256 GB SSD - NVMe, TLC
Display
14" WLED 1920 x 1200 / WUXGA @ 60 Hz
Graphics
Intel Iris Xe Graphics
Input Device
ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.2, 802.11a/b/g/n/ac/ax (Wi-Fi 6E)
3-cell - up to 14 hours
Accelerometer, magnetometer, gyro sensor, hall sensor, HP Tamper Lock
Security
Trusted Platform Module (TPM 2.0) Security Chip
31.56 cm x 22.405 cm x 1.92 cm
1.36 kg
Environmental Standards
TCO Certified Notebooks 9, ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro (available through downgrade rights from Windows 11 Pro) + Windows 11 Pro Licence - English
Processor / Chipset
CPU
Intel Core i5 (12th Gen) 1245U / 1.2 GHz
Max Turbo Speed
4.4 GHz
Number of Cores
10-core
Cache
L3 - 12 MB
Intel Turbo Boost Technology
RAM
16 GB (1 x 16 GB)
Max RAM Supported
64 GB
DDR5 SDRAM - non-ECC
Speed
4800 MHz
Rated Speed
4800 MHz
SO-DIMM 262-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC)
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1200 (WUXGA)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
WUXGA ultra wide-viewing angle (UWVA) anti-glare eDP
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
Video System Features
Functions as Intel UHD graphics (for single-channel memory)
Camera
Resolution
5 Megapixel
Camera Features
Privacy shutter, HP Auto Frame
Sound
Dual stereo speakers, dual array microphone
Codec
Realtek ALC3315
Audio Features
Output: Bang & Olufsen Audio, discrete amplifiers
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Gesture function, precision touchpad, multi-gesture clickpad, glass clickpad, spill-resistant, DuraKeys
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6E AX 211 - M.2 2230 (CNVi)
Miracast, dual stream (2x2), MU-MIMO
Wi-Fi CERTIFIED
3-cell lithium polymer
51.3 Wh
Run Time
Up to 14 hours
AC Adapter
Input
AC 115/230 V (50/60 Hz)
Output
45 Watt, 5 / 9 / 12 / 15 V, 5 A
Connections & Expansion
Interfaces Details
2 x USB4 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (charging) , USB 3.2 Gen 1 , HDMI , Headphone/microphone combo jack
Software
Software Included
HP Support Assistant, HP Power Manager, HP Hotkey Support, HP Secure Erase, HP Image Assistant, HP PC Hardware Diagnostics, HP MAC Address Manager, HP Notifications, HP Connection Optimizer, HP Sure Click, HP Privacy Settings, HP Cloud Recovery, HP Sure Sense, HP Sure Admin, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, HP Wake on WLAN, myHP, Touchpoint Customiser for Commercial, HP Image Assistant Gen5 (free download), HP Client Security Manager Gen7, Tile, HP Easy Clean, HP Smart Support (free download), HP Quick Touch, HP Connect for Microsoft Endpoint Manager, HP Patch Assistant (free download), HP Sure Recover Gen5, HP Sure Run Gen5, HP Sure Start Gen7, HP Driver Packs (free download), HP Manageability Integration Kit Gen4 (free download)
Integrated Options
Security
BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, HP Fast Charge, BIOS Update via Network, Secured-core PC capable
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion sensor
Security Slot Type
Kensington nano security slot
HP 45 Watt nPFC USB-C AC Adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FIPS 140-2 Level 2, FCC, RoHS, WEEE, A-Tick, ICES, Common Criteria EAL4+, KC, CIT, low halogen, ICCP
Localization
1.36 kg
6.9 cm x 44.9 cm x 30.5 cm
Sustainability Information
TCO Certified
- TCO Certified Notebooks 9
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (9)
Get more from your purchase from one of our essential accessories
H4HH HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £116.78
H4HH HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £145.96
H4HH HP USB-C TO RJ45 Adapter In Stock £187.85
H4HH HP Thunderbolt Dock G4 - HDMI, 2 x DP, Thunderbolt, USB-C - 1GbE, 2.5GbE In Stock £144.80
H4HH HP USB-C Power Adapter - 65 Watt In Stock £57.16
H4HH HP Prelude Top Load 15.6" Notebook Carrying Case In Stock £10.35
H4HH HP Thunderbolt Dock G4 - USB-C / Thunderbolt 4 - HDMI, 2 x DP, Thunderbolt, USB-C - 1GbE, 2.5GbE In Stock £193.84
H4HH HP USB-C LC Power Adapter - 65 Watt In Stock £15.28
H4HH HP Nano - Security Cable Lock In Stock £15.92
Warranty Packs (8)
Protect your investment by taking out one of our great value warranty packs
H4HH HP Care Pack Pick-Up and Return Service Extended Service Agreement 4 Years for EliteBook In Stock £104.74
H4HH HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £92.97
H4HH HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site In Stock £108.27
H4HH HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £104.34
H4HH HP Care Pack Pick-Up and Return Service Extended Service Agreement 5 Years Pick-Up and Return In Stock £138.87
H4HH HP EPACK 4 Year Onsite NBD+DMR (NB ONLY) In Stock £161.23
H4HH HP 3 Year Premium Care Notebook service In Stock £141.23
H4HH HP Carepack 5y Travel NextBusDay Notebook Only SVC In Stock £194.19
Other bundles (51)
H4HH HP USB-C To VGA Adapter In Stock £22.09
H4HH HP USB Travel Mouse In Stock £10.91
H4HH HP USB-C to HDMI 2.0 Adapter In Stock £46.71
H4HH HP USB G2 Stereo Headset In Stock £20.44
H4HH HP 128 Wired Mouse In Stock £8.56
H4HH HP 455 Programmable Keyboard - Wireless - UK In Stock £26.46
H4HH HP USB-C to RJ45 Adapter G2 In Stock £13.20
H4HH HP P27h G5 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £188.49
H4HH Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £240.58
H4HH Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A In Stock £234.68
H4HH Poly P5 1080P HD Webcam In Stock £36.52
H4HH Poly Voyager 4320 UC V4320-M C USB-A WW In Stock £124.75
H4HH Poly Voyager 4320 UC V4320 C USB-C WW In Stock £103.93
H4HH Poly Voyager Focus 2 UC-M USB-A with Stand In Stock £108.52
H4HH Poly TRIO C60 EXPANSION MICROPHONES In Stock £134.01
H4HH Poly Blackwire C3225 USB-A Headset In Stock £51.43
H4HH Poly EncorePro HW520 Stereo Headset (Noise Cancelling) In Stock £81.71
H4HH Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £53.34
H4HH Poly EncorePro HW510 Mono Headset (N/C) In Stock £86.11
H4HH Poly Voyager 4320 UC V4320-M C USB-A CS WW In Stock £108.73
H4HH Poly Voyager 4320 UC V4320-M C USB-C WW In Stock £98.60
H4HH Poly Voyager 4320 UC V4320 C USB-A CS WW In Stock £131.93
H4HH Poly Voyager 4310 UC V4310-M C USB-A WW In Stock £110.75
H4HH Poly Sync 20 SY20-M USB-A WW In Stock £72.80
H4HH Poly Voyager 4320 UC V4320 C USB-C CS WW In Stock £119.34
H4HH Poly Voyager 4320 UC V4320-M C USB-C CS WW In Stock £110.60
H4HH Poly Voyager 4310 UC V4310-M C USB-A CS WW In Stock £121.68
H4HH Poly Voyager 4310 UC V4310 C USB-A WW In Stock £113.52
H4HH Poly Voyager 4310 UC V4310 C USB-A CS WW In Stock £121.68
H4HH Poly Sync 10 SY10-M USB-A/C WW In Stock £60.31
H4HH Poly EncorePro 525 USB EP525 USB-A Headset In Stock £84.71
H4HH Poly EncorePro HW510 Mono Headset (VT) In Stock £73.73
H4HH Poly Voyager Focus 2 UC-M USB-C Headset with Stand In Stock £141.12
H4HH Poly Sync 40 SY40-M WW In Stock £139.01
H4HH Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £92.95
H4HH Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified In Stock £34.67
H4HH Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £33.49
H4HH Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £75.19
H4HH Poly Spare BT700 Bluetooth USB Adapter In Stock £58.49
H4HH Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £49.32
H4HH HyperX Pulsefire Mat Gaming Mouse Pad In Stock £12.57
H4HH HP OMEN 27" Full HD 165Hz Gaming Monitor In Stock £145.60
H4HH Poly Blackwire 3210 headset - on-ear - wired - USB-C - black In Stock £25.20
H4HH Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £65.77
H4HH Poly Blackwire 3310 headset - on-ear - wired - USB-A - black In Stock £28.00
H4HH Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £31.11
H4HH Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £29.33
H4HH Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £28.00
H4HH Poly EncorePro 515-M headset - on-ear - wired - USB-A - black In Stock £75.67
H4HH Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black In Stock £81.56
Type: Laptop
Screen Size: 14in
Hard Drive Capacity: 256GB
Graphics: Intel Iris Xe Graphics
Brand: HP
Price Range Ex VAT: £1000 - £1500
