HP EliteBook 840 G7 Intel Core i7-10510U 16GB 512GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: GM98WS00 Mfr#: 1J6D5EA#ABU
  • Core i7
  • IEEE 802.11n
A collaborative approach to work requires a powerful, secure, and durable laptop that keeps users connected and productive in any setting. Meet the demands of your multi-task, multi-place workday with the lightweight and beautifully designed HP EliteBook 840 G7.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP.
  • Fast performance, connectivity, and responsiveness
    Get the exceptional combination of responsive performance, connectivity and speed with a 10th Gen Intel Core processor that lets you launch, create, and connect fast and reliably.
  • HP Sure Sense
    Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
  • Fast and efficient wireless LAN
    The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6.
  • Automatic recovery from firmware attacks
    Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen6 automatically recovers the BIOS from malware, rootkits, or corruption.
  • Keep your PC's security protections in place
    Stop unwanted changes to security settings and help limit the spread of malware with HP Sure Run Gen3 which identifies, quarantines, and provides reporting on attackers trying to kill processes.
HP EliteBook 840 G7 Notebook - 14" - Intel Core i7 - 10510U - 16 GB RAM - 512 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (10th Gen) - 10510U / 1.8 GHz, up to 4.9 GHz / 8 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
512 GB SSD - SED, TCG Opal Encryption 2, NVMe, TLC
Display
14" WLED 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
Pointing stick, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax
3-cell
Hall sensor
Security
Trusted Platform Module (TPM 1.2) and firmware (TPM 2.0), fingerprint reader, smart card reader
32.36 cm x 21.47 cm x 1.79 cm
1.33 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (10th Gen) 10510U / 1.8 GHz
Max Turbo Speed
4.9 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (2 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
512 GB SSD M.2 2280 PCIe 3.0 x4 - Self-Encrypting Drive, TCG Opal Encryption 2, NVM Express (NVMe), triple-level cell (TLC)
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
Camera
Yes - HD
Video Resolutions
720p
Camera Features
Privacy shutter, IR camera
Sound
Stereo speakers, 3 multi-array microphone
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, pointing stick, ClickPad
Keyboard Backlight
Keyboard Layout
Precision touchpad, multi-gesture clickpad, glass clickpad
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6 AX 201
Ethernet Controller
Intel I219-V
Miracast, dual stream (2x2), MU-MIMO
Wi-Fi CERTIFIED
3-cell Lithium Ion
53 Wh
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Interfaces Details
2 x USB-C 3.1 (supports Thunderbolt) , USB 3.1 Gen 1 (charging) , USB 3.1 Gen 1 , HDMI , Headphone/microphone combo jack
Software
Software Included
HP Support Assistant, HP Hotkey Support, Windows Defender, HP Client Catalog, HP BIOS Config Utility, HP Image Assistant, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP Connection Optimizer, HP Sure Click, HP Fingerprint Sensor, Ivanti Management Suite, HP BIOSphere Gen5, HP Cloud Recovery, HP Sure Sense, HP Sure Recover Gen3, HP Client Management Script Library, HP Client Security Manager Gen6, HP SureStart Gen6, HP Sure Run Gen3
Integrated Options
Hall sensor
Security
Power-on password, Setup Password, BIOS Absolute Persistence, Power On Authentication, HP Fast Charge, Pre-boot Authentication, BIOS Update via Network, HP Secure Erase
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
HP 45 Watt Smart nPFC AC Adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, low halogen, ICCP, AUS/NZ
Localization
1.33 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
GM98 HP 65W Smart AC Adapter In Stock £17.31
GM98 HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £109.31
GM98 HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £138.07
Warranty Packs (8)
Protect your investment by taking out one of our great value warranty packs
GM98 HP Care Pack Pick-Up and Return Service Extended Service Agreement 4 Years for EliteBook In Stock £104.74
GM98 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £92.96
GM98 HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site In Stock £108.27
GM98 HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £104.33
GM98 HP Care Pack Pick-Up and Return Service Extended Service Agreement 5 Years Pick-Up and Return In Stock £138.87
GM98 HP EPACK 4 Year Onsite NBD+DMR (NB ONLY) In Stock £161.23
GM98 HP 3 Year Premium Care Notebook service In Stock £141.23
GM98 HP Carepack 5y Travel NextBusDay Notebook Only SVC In Stock £194.17
Other bundles (4)
GM98 HP USB-C To VGA Adapter In Stock £22.09
GM98 HP USB Travel Mouse In Stock £9.39
GM98 HP USB-C to HDMI 2.0 Adapter In Stock £46.71
GM98 HP P34hc G4 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £373.33
