Uniquely designed for the modern mobile professional, the HP EliteBook 840 is a highly secure and manageable PC offering powerful collaboration tools, enabling the enterprise workforce to be more productive and secure on the go or in the office.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP. -
High performance, high portability
Help speed up demanding business applications with an 8th Gen quad-core Intel Core processor. -
Fast and efficient wireless LAN
Get gigabit speed Wi-Fi with Wi-Fi 6 (802.11ax). -
Automatic recovery from firmware attacks
Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen5 automatically recovers the BIOS from malware, rootkits, or corruption. -
Protect critical security processes
To get control of your PC, attackers first need to take down its defenses. Keep critical security protections up and running and prevent unwanted changes to security settings with HP Sure Run Gen2, which provides resilience against attacks. -
Recovery simplified
Advanced malware attacks can destroy your OS and disrupt your business. HP Sure Recover Gen2 ensures fast, secure, and automated recovery of your OS with only a network connection, so you can minimize downtime and get back to business fast.
- HP EliteBook 840 G6 Notebook - 14" - Intel Core i7 - 8565U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (8th Gen) - 8565U / 1.8 GHz, up to 4.6 GHz / 8 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe, TLC, HP Value + 32 GB SSD cache (PCIe (NVMe)) (3D Xpoint (Optane))
- Display
- 14" WLED 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- Pointing stick, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
- Battery
- 3-cell - up to 17.25 hours
- Ambient light sensor
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 32.6 cm x 23.43 cm x 1.79 cm
- 1.48 kg
- Localisation
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8565U / 1.8 GHz
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz / PC4-19200
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC), HP Value
- SSD Cache
- 32 GB 3D Xpoint (Optane) (PCIe (NVMe))
Display
- 14" - IPS
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
- Keyboard Name
- HP Premium Collaboration Keyboard
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Camera Features
- IR camera, HP Privacy HD
- Sound
- Stereo speakers, 3 multi-array microphone
- Audio Features
- Output: noise-cancellation technology, Bang & Olufsen Audio
Input
- Keyboard, pointing stick, ClickPad
- Keyboard Layout
- UK
- Spill-resistant, multi-gesture clickpad
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 200
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Miracast, dual stream (2x2)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 3-cell lithium polymer
- Capacity
- 50 Wh
- Run Time
- Up to 17.25 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Interfaces Details
- 2 x USB 3.1 Gen 1 (charging) , USB-C (supports Thunderbolt) , HDMI , LAN , Dock , Headphone/microphone combo jack
Software
- Software Included
- HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Spare Key, Password Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Security Manager, HP Client Catalog, HP Credential Manager, Absolute Persistence, HP BIOS Config Utility, HP Device Access Manager, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, Native Miracast, HP JetAdvantage, HP PhoneWise, HP Connection Optimizer, HP Sure Click, Power On Authentication, HP BIOSphere Gen5, HP Client Security Gen5
- Case Material
- Aluminum
- Integrated Options
- Dockable
- Security
- Power-on password, BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MU-MIMO technology, Master Boot Record Security, HP Sure Run, HP Sure Recover, HP Wireless Wakeup, BIOS Update via Network, HP Sure Start Gen 5
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, low halogen, ICCP
- Localization
- HP Smart Buy
- 1.48 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
HP 65W Smart AC Adapter | In Stock | £17.92 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £115.06 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £143.82 |
Warranty Packs (8)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Pick-Up and Return Service Extended Service Agreement 4 Years for EliteBook | In Stock | £104.74 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site | In Stock | £92.96 |
HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site | In Stock | £108.27 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site | In Stock | £104.33 |
HP Care Pack Pick-Up and Return Service Extended Service Agreement 5 Years Pick-Up and Return | In Stock | £138.87 |
HP EPACK 4 Year Onsite NBD+DMR (NB ONLY) | In Stock | £161.23 |
HP 3 Year Premium Care Notebook service | In Stock | £141.23 |
HP Carepack 5y Travel NextBusDay Notebook Only SVC | In Stock | £194.17 |
Other bundles (3)
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.39 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £46.71 |
