HP EliteBook 840 G3 Intel Core i5-6200U 4GB 256GB SSD 14" Windows 7 Professional
Quicklinx: C7R1WS00 Mfr#: T9X25ET#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Impressively thin and light, the HP EliteBook 840 empowers users to create, connect, and collaborate, using enterprise-class performance technology that helps keep you productive in and out of the office.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light HP EliteBook 840.
  • Self-healing safeguard
    HP Sure Start with Dynamic Protection checks your BIOS every 15 minutes to detect attacks and corruption then self-heals the BIOS automatically.
  • Give your fingers a break
    Enjoy a remarkable balance of comfort and feedback with the HP Premium Keyboard engineered for accuracy.
  • Storage options galore
    Get the speed and space you need without having to use external storage. Dual drive support options quickly boot, wake, and run your system on a fast SSD and let you maintain access to your files with a high-capacity HDD.
  • Field ready
    Stand up to the workload with an EliteBook that passed MIL-STD 810G testing.
  • In-house serviceability
    Expand your system's memory, battery, storage, and WWAN components.
HP EliteBook 840 G3 Notebook - 14" - Intel Core i5 - 6200U - 4 GB RAM - 256 GB SSD - UK
Ultrabook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
256 GB SSD
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
33.8 cm x 23.7 cm x 1.89 cm
1.54 kg
Environmental Standards
- EPEAT Climate+
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
Ultrabook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
14" - TN
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Full HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Sound
Stereo speakers, two microphones
Codec
CX7501
HP Clear Sound Amp
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
46 Wh
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Interfaces Details
USB-C , 2 x USB 3.0 , DisplayPort , VGA , LAN , Dock , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Drivers & Utilities, Cyberlink PowerDVD, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, Drive Encryption, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Pixel Sharp, HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software
Case Material
Aluminum, magnesium alloy
Dockable
Security
HP DuraKeys, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, 1 USB 3.0 charging port, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, RoHS, WEEE
Localization
1.54 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
