Now employees can hit the road with a travel pro. The HP EliteBook 840 G1 industry leading Ultrabook is ultra-productive in and out of the office. Work with confidence thanks to proven enterprise technologies and enterprise security, performance and management features that will meet all your business needs.
Sleek and sturdy
It's time for an upgrade to the dramatically thin, light design of the HP EliteBook 840 G1 Ultrabook with a luxurious and soft touch finish.Join forces with the latest generation Intel architecture and operate at peak performance levels with Intel Smart Response Technology for disk cache and expand total storage options with an additional mini-card SSD.Dock up for an enterprise desktop experience using the optional UltraSlim Docking Station with a convenient side connector and dual DisplayPorts for multiple display support.Deliver graphics intensive projects right from your EliteBook with powerful AMD Radeon HD 8750M discrete graphics. -
It's all about the connections
Exercise full control over your wireless connections through a single user interface with support for most networks, including optional new 4G WWAN, using HP Connection Manager.Easily share your internet connection with up to five devices with HP Wireless Hotspot. Help colleagues get online and improve productivity.Take productivity to a whole new level with innovative software like HP ePrint and HP PageLift on the HP EliteBook 840 G1.Bridge distances on the HP EliteBook 800 series with Microsoft Lync, premium audio/video and optional full-HD display. -
Solid security
HP Sure Start restores productivity and reduces IT help desk calls in the event of a BIOS attack or corruption. Developed with HP Labs, HP Sure Start helps reduce down time for users and IT.Stay up and running. HP BIOS Protection offers enhanced protection against virus attacks to the BIOS and other security threats, and is designed to help prevent data loss and reduce downtime.Safeguard data, devices and identities with HP's hassle-free Client Security portfolio, including HP Drive Encryption, HP Device Access Manager with Just In Time Authentication, and HP Secure Erase.Ensure smooth sailing with stable and consistent images, managed lifecycle transitions and Global Series support you can rely on. -
Road ready
Never fear accidental bumps and minor spills. The HP EliteBook 840 G1 Ultrabook pass MIL-STD 810G testing for drops, vibration, shock, dust, humidity, altitude, high temperature, low temperature, temperature shock, and ESD Tests.Designed to be travel-tough, the HP EliteBook 840 G1 Ultrabook features a new, soft touch finish and pass MIL-STD 810G testing for drops, vibration, shock, dust, humidity, altitude, high temperature, low temperature, temperature shock, and ESD Tests, and endure HP's Total Test Process.Enjoy the intuitive control of the tough Corning Gorilla Glass touch screen (select models only) that lets you make the most of Windows 8.
- HP EliteBook 840 G1 Notebook - 14" - Intel Core i5 - 4310U - vPro - 4 GB RAM - 500 GB HDD
- Product Type
- Ultrabook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (4th Gen) - 4310U / 2 GHz, up to 3 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm + 32 GB SSD cache (M.2)
- Display
- 14" LED backlight 1600 x 900 / HD+
- Graphics
- AMD Radeon HD 8750M / Intel HD Graphics 4400
- Video Memory
- 1 GB GDDR5 SDRAM
- Input Device
- Pointing stick
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 3-cell - up to 13.25 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
- 33.89 cm x 23.7 cm x 2.1 cm
- 1.67 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
- Product Type
- Ultrabook
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4310U / 2 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Enhanced SpeedStep technology, Intel Turbo Boost Technology 2.0, Intel Active Management Technology 9.0 (AMT 9.0)
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 7200 rpm
- SSD Cache
- 32 GB (M.2)
Display
- 14" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- HD+ standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 1 GB GDDR5 SDRAM
- Video System Features
- AMD PowerPlay Technology, AMD Dynamic Switchable Graphics
- Camera
- Yes - 1280 x 720
- Sound
- Stereo speakers, stereo microphone
- Codec
- IDT 92HD91
- High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
- Keyboard, touchpad, pointing stick
- Volume control, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-N 7260AN - PCI Express Half Mini Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 3-cell lithium polymer
- Capacity
- 50 Wh
- Run Time
- Up to 13.25 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 18.5 V
Connections & Expansion
- 4 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock , Battery
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, HP Spare Key, HP Client Security, Device Access Manager with Just In Time Authentication, HP Secure Erase, HP File Sanitizer, Drive Encryption, HP Disk Sanitizer, Getting Started guide with Windows 8
- Case Material
- Aluminum, magnesium alloy
- Dockable
- Security
- Power-on password, HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP DisplaySafe, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Pre-Boot Security, HP Roaming Alert, Intel My WiFi Technology, 1 USB 3.0 charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, EAL 4+, A-Tick, ICES, KC, CIT
- Localization
- 1.67 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
