Impressively thin and light, the HP EliteBook 820 empowers users to create, connect, and collaborate, using enterprise-class performance technology that helps keep you productive in and out of the office.
Portable powerhouse
Combine high performance technology and long battery life with Windows 10 Pro, 6th Gen Intel® Core™ processors, and a PCIe Gen3 SSD.3 Unlock next generation memory performance with DDR4 memory for your most demanding business applications.
Slim new design with all the right ports
Connect to essential ports you need without the hassle of dongles. At just 18.9 mm, the ultraslim and light HP EliteBook 820 comes with VGA, Display Port, RJ-45, USB, USB-C™, and enterprise docking capabilities.
Strong security, powerful manageability
Protect, detect, and recover from malicious attacks with HP Sure Start with Dynamic Protection - the industry’s first self-healing BIOS that monitors and corrects BIOS corruption every 15 minutes.
Designed for collaboration
Replace your speaker phone with the HP EliteBook 820 with Audio by Bang & Olufsen plus HP Noise Reduction Software that provides a rich collaboration experience for applications like Skype for Business.
Key Features
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light HP EliteBook 820.
Self-healing safeguard
HP Sure Start with Dynamic Protection checks your BIOS every 15 minutes to detect attacks and corruption then self-heals the BIOS automatically.
Give your fingers a break
Enjoy a remarkable balance of comfort and feedback with the HP Premium Keyboard engineered for accuracy.
Field ready
Stand up to the workload with an EliteBook that passed MIL-STD 810G testing.
In-house serviceability
Expand your system’s memory, battery, storage, and WWAN.
Give your speakers a boost
Experience the difference with HP Clear Sound AMP and the HP EliteBook 820 speakers.
Cut out the chatter
Suppress background noise including keyboard clicks with HP Noise Reduction Software.
See it clearly
Pick the right display for the way you work with FHD touch display.
Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light HP EliteBook 820. -
HP Sure Start with Dynamic Protection checks your BIOS every 15 minutes to detect attacks and corruption then self-heals the BIOS automatically. -
Enjoy a remarkable balance of comfort and feedback with the HP Premium Keyboard engineered for accuracy. -
Field ready
Stand up to the workload with an EliteBook that passed MIL-STD 810G testing. -
Expand your system's memory, battery, storage, and WWAN. -
- HP EliteBook 820 G3 Notebook - 12.5" - Intel Core i5 - 6300U - vPro - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (6th Gen) - 6300U / 2.4 GHz, up to 3 GHz / 3 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe
- Display
- 12.5" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Input Device
- Pointing stick
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell - up to 12.5 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 31 cm x 21.89 cm x 1.89 cm
- 1.26 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6300U / 2.4 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Enhanced SpeedStep technology, Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe 3.0 x4 - NVM Express (NVMe)
Display
- 12.5" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 720p
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, two microphones
- Codec
- CX7501
- Audio Features
- Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
- Keyboard, touchpad, pointing stick
- Keyboard Layout
- UK
- Volume control, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - PCI Express Half Mini Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Miracast, Wake-on-LAN (WOL)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 3-cell lithium polymer
- Capacity
- 44 Wh
- Run Time
- Up to 12.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Slots
- 1 x SIM card (1 free)
- Interfaces Details
- 2 x USB 3.0 , USB-C , DisplayPort , VGA , LAN , Dock , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, HP Spare Key, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software, HP Image Assistant
- Case Material
- Aluminum, magnesium alloy
- Dockable
- Security
- HP 3D DriveGuard, Intel Active Management Technology (iAMT), HP DuraKeys, HP SpareKey, HP BIOS Protection, HP SureStart, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port, Pre-boot Authentication
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 1.26 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
Essential Accessories (4)
Get more from your purchase from one of our essential accessories
HP 90W Smart AC Adapter | In Stock | £22.69 |
HP 65W Smart AC Adapter | In Stock | £18.54 |
HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack | In Stock | £13.44 |
HP Dual Head Keyed Cable Lock | In Stock | £43.00 |
Other bundles (6)
HPE DisplayPort to HDMI Adapter | In Stock | £13.44 |
HPE HP DisplayPort to DVI Adapter | In Stock | £17.23 |
HPE DisplayPort to VGA Adapter | In Stock | £16.40 |
HP USB Travel Mouse | In Stock | £10.58 |
HP X4000b Bluetooth Mouse | In Stock | £28.71 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
