HP EliteBook 820 G2 Intel Core i5-5300U 8GB 256GB SSD 12.5" Windows 7 Professional 64-bit
Quicklinx: BHSMWS00 Mfr#: J8R93EA#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
The HP EliteBook 820 comes equipped with all of the features you need to get your business tasks completed to the highest of standards. With a proven record for solid, reliable performance, the HP 820 also comes with robust management and security features to give you extra peace of mind.
Take advantage of the SmartCard reader and Trusted Platform Module security chip to keep your laptop under lock and key when you’re not around.
With impressive battery life and weighing just 1.34kg, you’ll find the EliteBook 820 the ideal portable companion – perfect if you travel a lot for work or need to work remotely often.
Its 12.5-inch LED backlight display comes in Full HD so you can enjoy crystal clear images, while the stereo speakers provide high definition audio – handy if you’re using the integrated webcam for a business call.
With 8GB RAM and 256GB solid state drive, there’s plenty of room to store even the largest of files and documents without compromising on speed and performance.
  • The simplicity of touch
    Enjoy the intuitive control of Windows 8.1 and impressive clarity of the optional FHD touchscreen featuring tough Corning Gorilla Glass 3.
  • Storage options galore
    The latest storage options, including PCIe SSD, ensure optimum performance from your HP EliteBook.
  • Effortless manageability
    Enjoy easy integration with HP Touchpoint Manager, HP Client Management Solutions, and Intel vPro technology.
  • Customized protection
    HP BIOSphere keeps mission-critical data and systems protected with customizable security.
  • Self-healing safeguard
    HP Sure Start detects corruption and self-heals the BIOS.
  • Expand your view
    Stay productive throughout the day with the optional HP UltraSlim Docking Station.
HP EliteBook 820 G2 Notebook - 12.5" - Intel Core i5 - 5300U - vPro - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Platform Technology
Intel vPro Platform
Intel Core i5 (5th Gen) - 5300U / 2.3 GHz, up to 2.9 GHz / 3 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
256 GB SSD
Display
12.5" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 5500
Input Device
Pointing stick
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
31 cm x 21.5 cm x 2.1 cm
1.34 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
CPU
Intel Core i5 (5th Gen) 5300U / 2.3 GHz
Max Turbo Speed
2.9 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Platform Technology
Intel vPro Platform
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD SATA 6Gb/s
Display
12.5"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Full HD ultra wide-viewing angle (UWVA) anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Sound
Stereo speakers, two microphones
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
Miracast
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
46 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
3 x USB 3.0 , DisplayPort , Headphone/microphone combo jack , LAN , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, Foxit PhantomPDF Express, HP Mobile Connect, HP Systems Software Manager (free download), HP PageLift, HP UEFI System Diagnostics, HP Wireless Hotspot, Getting Started guide with Windows 8, HP GPS and Location, HP Client Catalogue (free download), HP Client Security Manager, HP Driver Packs, HP BIOS Config Utility, LANDesk Management Suite (free download), HP Device Access Manager
Case Material
Magnesium-aluminum alloy
Dockable
Security
Power-on password, HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, HP Roaming Alert, Intel My WiFi Technology, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, EAL 4+, A-Tick, ICES, KC, CIT
Localization
1.34 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
