HP EliteBook 755 G2 AMD A10 Pro-7350B 4GB 500GB 15.6" Windows 7 Professional 64-bit
Quicklinx: BHPMWS00 Mfr#: J0X38AW#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
The thin and light design with optional FHD touch display makes the HP EliteBook 700 series ideal for professionals in and out of the office. Work proficiently and confidently with HP technology and AMD PRO A-Series APUs.
  • At your fingertips
    The HP EliteBook 755 G2 delivers future-ready performance at an exceptional price. Featuring AMD PRO A-Series APUs now with revolutionary HSA technology, a lightweight design, and an optional FHD touch display that allows you to navigate easily and get work done.
  • Field ready
    Never fear bumps and minor spills. The thin and light HP EliteBook 755 G2 endures HP's Total Test Process and is designed to undergo MIL-SPEC 810G testing.
  • Self-healing safeguard
    HP Sure Start is the way to help ensure a proper boot-up thanks to corruption detection, a self-healing BIOS, and recovery that restarts where it left off if the update stalls, fails, or is corrupted.
  • Featuring
    The latest AMD PRO A-Series APUs with HSA technology help unlock true business computing and deliver outstanding total cost of ownership, optimal manageability, and security features. Simply put, AMD PRO A-Series APUs are easy to support with the power to perform.Enjoy the stunning graphics provided by affordable AMD Radeon Graphics.Each HP EliteBook 755 G2 works with HP Client Management Solutions and DASH support.Rely on stable and consistent images, managed lifecycle transitions and Elite support.HP BIOSphere keeps mission-critical data and systems protected with customizable security.
HP EliteBook 755 G2 Notebook - 15.6" - AMD A10 - PRO-7350B - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
AMD A10 PRO-7350B / 2.1 GHz, up to 3.3 GHz / 4 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
AMD Radeon R6
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
3-cell - up to 8 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
37.55 cm x 25.36 cm x 2.149 cm
1.99 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year
Notebook
Recommended Use
Small business, corporate business
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Processor / Chipset
CPU
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
Cache
L2 - 4 MB
64-bit Computing
Chipset
AMD A76M FCH
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 7200 rpm
Display
15.6" - TN
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Full HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
AMD Radeon R6
Camera
Video Resolutions
1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
Keyboard, touchpad
Spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111EP
Remote Management Protocol
SNMP 2
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell Lithium Ion
50 Wh
Run Time
Up to 8 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
4 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Connection Manager, HP ePrint, HP Hotkey Support, HP Spare Key, Password Manager, HP Client Security, Device Access Manager with Just In Time Authentication, HP Secure Erase, HP File Sanitizer, Drive Encryption, HP Disk Sanitizer, HP BIOSphere
Case Material
Aluminum, magnesium alloy
Dockable
Security
HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP DisplaySafe, HP BIOS Protection, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, HP Roaming Alert
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, FIPS 140-2, WEEE, EAL 4+, A-Tick, ICES, KC, CIT
Localization
1.99 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance
40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
