Enjoy the thin, light, and cost effective HP EliteBook 745. Be ultra-productive by staying connected with impressive collaboration and connectivity features for your growing business on the HP EliteBook 745.
Slim new design with all the right ports
Connect with all of the essential ports you need without the hassle of dongles - in a thin and light design. At just 18.9 mm, the HP EliteBook 745 comes with VGA, Display Port, RJ-45 and enterprise docking capabilities.
Strong security, powerful manageability
Protect, detect, and recover from malicious attacks with HP Sure Start - the industry’s first self-healing BIOS. Keep your team up and running with HP Touchpoint Manager and DASH manageability to help monitor the HP EliteBook 745.
Designed for collaboration
Replace your speaker phone with the HP EliteBook 745 with Audio by Bang & Olufsen that provides a rich collaboration experience for applications like Skype for Business.
Great features and value, from HP!
The ultrathin HP EliteBook 745 delivers tremendous value. HP is the first to offer the new high-performance AMD PRO A12 APU, the first commercial APU with integrated Radeon™ R7 graphics that help harness the full potential of your applications.
Slim design with all the right ports
Connect with all of the essential ports you need without the hassle of dongles - in a thin and light design. The HP EliteBook 745 comes with VGA, Display Port, RJ-45 and enterprise docking capabilities. -
Protect, detect, and recover from malicious attacks with HP Sure Start - the self-healing BIOS. Keep your team up and running with HP Touchpoint Manager and DASH manageability to help monitor the HP EliteBook 745. -
Replace your speaker phone with the HP EliteBook 745 with Audio by Bang & Olufsen that provides a rich collaboration experience for applications.
- HP EliteBook 745 G3 Notebook - 14" - AMD A10 - PRO-8700B - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- AMD A10 PRO-8700B / 1.8 GHz, up to 3.2 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- AMD Radeon R6
- Input Device
- Pointing stick
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell - up to 7 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 33.8 cm x 23.7 cm x 1.89 cm
- 1.48 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years ¦ Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 6Gb/s / 7200 rpm
Display
- 14" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- Vivid Color, Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- AMD Radeon R6
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Codec
- CX7501
- DTS Studio Sound
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, touchpad, pointing stick
- Keyboard Layout
- UK
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5762
- Miracast
- IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Capacity
- 46 Wh
- Run Time
- Up to 7 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Slots
- 1 x Micro-SIM card (1 free)
- Interfaces Details
- USB 3.0 ¦ USB-C ¦ DisplayPort ¦ VGA ¦ Headphone/microphone combo jack ¦ LAN ¦ Dock ¦ USB 3.0 (charging)
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, HP Recovery Disc Creator, Skype, LANDesk Management Suite, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Foxit PhantomPDF Express, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, Drive Encryption, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), Absolute Persistence, HP Pixel Sharp, HP CIK for Microsoft SCCM (free download), HP Noise Reduction Software, HP Driver Packs (free download)
- Case Material
- Aluminum, magnesium alloy
- Dockable
- Security
- HP 3D DriveGuard, HP DuraKeys, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-boot Authentication
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, RoHS, WEEE
- Localization
- 1.48 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
HP 90W Smart AC Adapter | In Stock | £20.21 |
HP 45W Adaptor NPFC Smart RC 4.5MM NSLIM | In Stock | £20.60 |
HP 65W Smart AC Adapter | In Stock | £17.06 |
Other bundles (2)
HPE DisplayPort to VGA Adapter | In Stock | £13.14 |
HP USB Travel Mouse | In Stock | £9.23 |
