HP EliteBook 725  A8-8600B 4GB 500GB 12.5 Windows 10 Pro
Quicklinx: CMX5WS00 Mfr#: T4H64EA#ABU
  • IEEE 802.11n
Enjoy the thin, light, and cost effective HP EliteBook 725. Be ultra-productive by staying connected with impressive collaboration and connectivity features for your growing business on the HP EliteBook 725.
Slim new design with all the right ports
Connect with all of the essential ports you need without the hassle of dongles - in an ultra-slim design. At just 18.9 mm, the HP EliteBook 725 comes with VGA, Display Port, RJ-45 and enterprise docking capabilities.
Strong security, powerful manageability
Protect, detect, and recover from malicious attacks with HP Sure Start - the industry’s first self-healing BIOS. Keep your team up and running with HP Touchpoint Manager and DASH manageability to help monitor the HP EliteBook 725.
Designed for collaboration
Replace your speaker phone with the HP EliteBook 725 with Audio by Bang & Olufsen that provides a rich collaboration experience for applications like Skype for Business.
Great features and value, from HP!
The ultrathin HP EliteBook 725 delivers tremendous value. HP is the first to offer the new high-performance AMD PRO A12 APU, the first commercial APU with integrated Radeon™ R7 graphics that help harness the full potential of your applications.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light touch optional HP EliteBook 725.
  • Self-healing safeguard
    HP Sure Start detects attacks, corruption and self-heals the BIOS automatically.
  • Give your fingers a break
    Keep focused without the distraction of a noisy keyboard using the HP Premium Keyboard engineered for comfort.
  • Field ready
    Stand up to the workload with an EliteBook that passed MIL-STD 810G testing.
  • In-house serviceability
    Easily expand your system's serviceable components.
  • Give your speakers a boost
    Help make good speakers sound great with HP Clear Sound Amp.
HP EliteBook 725 G3 Notebook - 12.5" - AMD A8 - PRO-8600B - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
AMD A8 PRO-8600B / 1.6 GHz, up to 3 GHz / 2 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Display
12.5" LED backlight 1366 x 768 / HD
Graphics
AMD Radeon R6
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
3-cell - up to 7.25 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
31.1 cm x 21.89 cm x 1.89 cm
1.26 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Display
12.5" - TN
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
AMD Radeon R6
Camera
Yes - HD
Sound
Stereo speakers, two microphones
Codec
ALC3228
DTS Studio Sound
Audio Features
Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Spill-resistant, touchpad with gesture support
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265
Network Interface
Gigabit Ethernet
Ethernet Controller
Broadcom BCM5762
Wi-Fi CERTIFIED, DASH 1.1
3-cell Lithium Ion
44 Wh
Run Time
Up to 7.25 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Interfaces Details
2 x USB 3.0 , USB-C , DisplayPort , VGA , LAN , Dock , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
HP Recovery Disc Creator, Skype, LANDesk Management Suite, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Pixel Sharp, HP Driver Packs, HP CIK for Microsoft SCCM (free download), HP Noise Reduction Software
Case Material
Magnesium-aluminum alloy
Dockable
Security
HP 3D DriveGuard, HP DuraKeys, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, WEEE
Localization
1.26 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
