Get the performance you need to bring your vision to life with the premium design of the ultraslim HP EliteBook 1050 business notebook with optional NVIDIA GeForce GTX 1050 graphics.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP. -
High performance, high portability
Experience the power and speed of up to an 8th Gen hexa-core Intel Core processor in the HP EliteBook 1050 ultraslim business notebook with optional NVIDIA GeForce GTX 1050 graphics. -
A modern docking solution
Quickly transition to desktop productivity with a single USB-C -cable. The optional HP Thunderbolt Dock G2 delivers enterprise manageability and an optional audio module. -
Preserve your privacy
Never wonder if someone is watching you with the added peace-of-mind that comes from the optional HP Privacy Camera, with a physical shutter to protect from malicious surveillance. -
Keep visual hackers in the dark
Instantly protect against visual hacking with the optional HP Sure View Gen2 integrated privacy screen. At the touch of a button your screen appears unreadable to those around you while you see your content clearly. -
Browse and open attachments confidently
Help protect your PC from websites, attachments, malware, ransomware, and viruses with hardware-enforced security from HP Sure Click.
- HP EliteBook 1050 G1 Notebook - 15.6" - Intel Core i7 - 8750H - 32 GB RAM - 1 TB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (8th Gen) - 8750H / 2.2 GHz, up to 4.1 GHz / 9 MB Cache
- Memory
- 32 GB DDR4 (2 x 16 GB)
- Storage
- 1 TB SSD - NVMe, TLC
- Display
- 15.6" LED backlight HP SureView 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 1050 / Intel UHD Graphics 630
- Video Memory
- 4 GB GDDR5 SDRAM
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, NFC, Bluetooth 5.0
- Battery
- 6-cell - up to 16 hours
- Hood sensor, ambient light sensor
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Pike silver
- 36 cm x 25.4 cm x 1.89 cm
- 2.06 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8750H / 2.2 GHz
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- 6-core
- Cache
- L3 - 9 MB
- 64-bit Computing
- RAM
- 32 GB (2 x 16 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 1 TB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC)
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 650 cd/m²
- Colour Gamut
- 100% sRGB
- Privacy Technology
- HP SureView
- Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR
- Keyboard Name
- HP Premium Collaboration Keyboard
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Video System Features
- NVIDIA Optimus
- Camera
- Yes - HD
- Camera Features
- IR camera, Windows Hello
- Sound
- Stereo speakers, dual array microphone
- Audio Features
- Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Spill-resistant, ClickPad with gesture support, glass with chemical etched surface, two-finger zoom (pinch), two-way scroll
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560
- Technology
- 6-cell lithium polymer
- Installed Qty
- 1
- Capacity
- 95.6 Wh
- Run Time
- Up to 16 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 150 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- 2 x USB-C 3.1 (supports Thunderbolt) , USB 3.0 (charging) , USB 3.0 , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Velocity, HP Secure Erase, HP Client Catalog, HP BIOS Config Utility, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP JetAdvantage, HP Wireless Wakeup, HP Workwise (free download), HP BIOSphere Gen4, HP Client Security Suite Gen4, HP Manageability & Integration Kit Gen2 (free download), HP Sure Run, HP Sure Recover, HP Sure Start Gen4, HP Driver Packs (free download)
- Pike silver
- Case Material
- Aluminum
- Integrated Options
- Security
- Power-on password, HP DuraKeys, Setup Password, Automatic DriveLock, HP DriveLock, Power On Authentication, Pre-boot Authentication, Master Boot Record Security, BIOS Update via Network
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Low halogen
- Localization
- 2.06 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine wave
- Shock Tolerance (non-operating)
- 240 g @ 2 ms half-sine wave
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £115.06 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £143.82 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site | In Stock | £122.39 |
Other bundles (2)
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.39 |
