HP EliteBook 1040 x360 G5 w/SureView Core i5-8250U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: FBV2WS00 Mfr#: 5DF66EA#ABU
  • Core i5
  • IEEE 802.11n
The compact, ultraslim, amazingly light HP EliteBook x360 1040 now features four use modes to get work done, take notes, share content, and enjoy some downtime.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful security, collaboration, and connectivity features from HP.
  • Take note of it
    The optional HP Rechargeable Active Pen with 4096 levels of pressure provides an authentic and inspiring writing and drawing experience, attaches magnetically to your device, and notifies you if it's left behind with a pen proximity alert.
  • A modern docking solution
    Quickly transition to desktop productivity with a single USB-C cable. The optional HP Thunderbolt Dock G2 delivers enterprise manageability and an optional audio module.
  • Keep visual hackers in the dark
    Instantly protect against visual hacking with the optional HP Sure View Gen2 integrated privacy screen. At the touch of a button your screen appears unreadable to those around you while you see your content clearly.
  • Browse and open attachments confidently
    Help protect your PC from websites, attachments, malware, ransomware, and viruses with hardware-enforced security from HP Sure Click.
  • Firmware-level protection
    Protect the firmware that antivirus can't reach! The hardware-enforced self-healing protection offered by HP Sure Start Gen4 automatically recovers the BIOS from malware, rootkits, or corruption.
HP EliteBook x360 1040 G5 Notebook - 14" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD - UK
Notebook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD - NVMe
Display
14" WLED touchscreen HP SureView 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
4-cell
Accelerometer, ambient light sensor, magnetometer, gyro sensor, hall sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
32.14 cm x 21.5 cm x 1.69 cm
1.35 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i5 (8th Gen) 8250U / 1.6 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2666 MHz
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
700 cd/m²
Colour Gamut
100% sRGB
Privacy Technology
HP SureView
Panel Self Refresh (PSR), Full HD eDP anti-glare, Corning Gorilla glass 5
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Camera Features
IR camera
Sound
Four speakers, 3 multi-array microphone
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, gesture function
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
4-cell lithium polymer
56.2 Wh
AC Adapter
Input
Output
65 Watt, 15 V
Connections & Expansion
Interfaces Details
2 x USB-C (supports Thunderbolt) , USB 3.1 Gen 1 (charging) , HDMI , Headphone/microphone combo jack
Integrated Options
Security
Power-on password, HP DuraKeys, HP Automatic Drive Lock, HP DriveLock, Pre-boot Authentication, Master Boot Record Security, HP Wireless Wakeup, BIOS Update via Network
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington nano security slot
USB-C power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, ICCP
Localization
1.35 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
5 - 95%
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
FBV2 HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £116.78
FBV2 HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £145.96
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
FBV2 HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site In Stock £122.40
Other bundles (2)
FBV2 HP USB-C To VGA Adapter In Stock £22.09
FBV2 HP USB Travel Mouse In Stock £10.91
