The sophisticated style of the HP EliteBook 1040 Ultrabook complements the innovative performance, security, and manageability features that help bring out your finest work.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, collaboration-ready HP EliteBook 1040. -
Performance to get the job done
Innovative performance with 6th Gen Intel Core processor, PCIe SSDs, and long battery life lets you work, surf, and connect with colleagues. -
Easy connections
Instantly protect against visual hacking with the optional HP Sure View integrated privacy screen, featuring 3M privacy technology. At the touch of a button your screen appears dark to those around you while you see your content clearly. -
Give your fingers a break
Enjoy a remarkable balance of comfort and feedback with the HP Premium Keyboard. -
Strong security
Protect, detect, and recover from malicious BIOS attacks with HP Sure Start with Dynamic Protection - the industry's first self-healing BIOS that monitors and corrects BIOS corruption in real-time. -
Safeguard data and devices
Help protect your PC with multifunction authentication using a fingerprint reader, SmartCard Reader, and TPM.
- HP EliteBook 1040 G3 Notebook - 14" - Intel Core i7 - 6500U - 8 GB RAM - 512 GB SSD - 4G LTE - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 512 GB SSD
- Display
- 14" LED backlight touchscreen 2560 x 1440 / WQHD
- Graphics
- Intel HD Graphics 520
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, NFC, Bluetooth 4.2, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE
- Service Provider
- Service not included
- Battery
- 6-cell - up to 9.75 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 33.7 cm x 23.45 cm x 1.65 cm
- 1.54 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6500U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
Storage
- Main Storage
- 512 GB SSD M.2 SATA 6Gb/s
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 2560 x 1440 (WQHD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 340 cd/m²
- Corning Gorilla glass 3, Panel Self Refresh (PSR), QHD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 1280 x 720
- Camera Features
- 720p HD movie recording, low light enhancement
- Sound
- Stereo speakers, two microphones
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Volume control, spill-resistant, multi-touch touchpad, glass with chemical etched surface
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- Intel Wireless Display (WiDi), Miracast
- IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Generation
- 4G
- Technology
- CDMA, EDGE, HSPA+, LTE, DC-HSPA+
- Controller
- HP lt4120 - M.2 Card
- Max Transfer Rate
- 150 Mbps
- Service Provider
- Technology
- 6-cell lithium polymer
- Capacity
- 45.6 Wh
- Run Time
- Up to 9.75 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- Interfaces Details
- 2 x USB 3.0 , USB-C , Dock , HDMI , Headphone/microphone combo jack
Software
- Software Included
- HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, HP Spare Key, Password Manager, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Credential Manager, HP Client Catalogue (free download), Absolute Persistence, LANDesk Management Suite (free download), HP CIK for Microsoft SCCM (free download), HP Noise Reduction Software, HP Image Assistant (free download)
- Case Material
- Aluminum
- Dockable
- Security
- HP DuraFinish, HP DuraKeys, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 2 x USB 3.0 charging port, Pre-boot Authentication, HP Sure Start with Dynamic Protection
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, CCC, FCC
- Localization
- 1.54 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
