With great power, comes great productivity. Our most powerful ultraslim 35.56 cm (14") diagonal business notebook accelerates your day-to-day, and makes even your hardest tasks a breeze-with powerful multitasking, on-the-go collaboration, and industry-leading security.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light HP EliteBook 1040. -
High performance, high portability
Combine power and speed with 7th Gen quad-core Intel Core processor (H-Series), optional PCIe Gen3 SSD, DDR4 memory. -
Browse confidently
Help protect your PC from infected websites, malware, ransomware, and viruses with HP Sure Click-hardware-enforced security for web browsers. -
Keep visual hackers in the dark
Instantly protect against visual hacking with the optional HP Sure View integrated privacy screen. At the touch of a button your screen appears unreadable to those around you while you see your content clearly. -
Self-healing safeguard
Start with a genuine HP BIOS every time. HP Sure Start Gen3 monitors in-memory BIOS, recovers the platform without user or admin intervention, restores the BIOS to a custom state, and is enterprise ready for centralized management. -
Charge fast
Work and play with long battery life, and recharge up to 50% battery life in just 30 minutes with an HP fast charging battery.
- HP EliteBook 1040 G4 Notebook - 14" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 256 GB SSD - HP Z Turbo Drive, NVMe, TLC
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 6-cell - up to 18 hours
- Hood sensor
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Natural silver, diamond cut design
- 32.89 cm x 23.28 cm x 1.59 cm
- 1.36 kg
- Localisation
- Limited warranty - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - HP Z Turbo Drive, NVM Express (NVMe), triple-level cell (TLC)
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 340 cd/m²
- Colour Gamut
- 100% sRGB
- Ultra Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- IR camera, Windows Hello
- Sound
- Stereo speakers, dual array microphone
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Multi-touch touchpad, glass with chemical etched surface
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
- Miracast, dual stream (2x2)
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 6-cell Lithium Ion
- Capacity
- 67 Wh
- Run Time
- Up to 18 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 5 / 9 / 10 / 12 / 15 / 20 V
Connections & Expansion
- Interfaces Details
- 2 x USB 3.1 Gen 1 (charging) , 2 x USB-C 3.1 (supports Thunderbolt 3) , HDMI , Headphone/microphone combo jack
Software
- Software Included
- HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, Device Access Manager, HP Velocity, HP Manageability, HP Client Catalog, HP BIOS Config Utility, HP 3D DriveGuard, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP System Software Manager, HP Client Security Suite Gen3, HP BIOSphere Gen3, HP JetAdvantage, HP Wireless Wakeup, HP Management Integration Kit for Microsoft System Center Configuration Manager (free download), HP Sure Click, HP Driver Packs (free download)
- Case Material
- Aluminum
- Integrated Options
- Hood sensor
- Security
- Power-on password, Setup Password, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, HP Fast Charge, MIL-STD-810G tested, HP Sure Start Gen 3
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter
- Localization
- 1.36 kg
Sustainability Information
- TCO Certified
