HP EliteBook 1040 G4 Core i7-7500U 8GB 256GB SSD 14" Windows 10 Pro
Quicklinx: DVCJWS00 Mfr#: 1EP88EA#ABU
  • Core i7
  • IEEE 802.11n
With great power, comes great productivity. Our most powerful ultraslim 35.56 cm (14") diagonal business notebook accelerates your day-to-day, and makes even your hardest tasks a breeze-with powerful multitasking, on-the-go collaboration, and industry-leading security.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light HP EliteBook 1040.
  • High performance, high portability
    Combine power and speed with 7th Gen quad-core Intel Core processor (H-Series), optional PCIe Gen3 SSD, DDR4 memory.
  • Browse confidently
    Help protect your PC from infected websites, malware, ransomware, and viruses with HP Sure Click-hardware-enforced security for web browsers.
  • Keep visual hackers in the dark
    Instantly protect against visual hacking with the optional HP Sure View integrated privacy screen. At the touch of a button your screen appears unreadable to those around you while you see your content clearly.
  • Self-healing safeguard
    Start with a genuine HP BIOS every time. HP Sure Start Gen3 monitors in-memory BIOS, recovers the platform without user or admin intervention, restores the BIOS to a custom state, and is enterprise ready for centralized management.
  • Charge fast
    Work and play with long battery life, and recharge up to 50% battery life in just 30 minutes with an HP fast charging battery.
HP EliteBook 1040 G4 Notebook - 14" - Intel Core i7 - 7500U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD - HP Z Turbo Drive, NVMe, TLC
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Input Device
ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
6-cell
Hood sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Natural silver, diamond cut design
32.89 cm x 23.28 cm x 1.59 cm
1.36 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (7th Gen) 7500U / 2.7 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - HP Z Turbo Drive, NVM Express (NVMe), triple-level cell (TLC)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
340 cd/m²
Colour Gamut
100% sRGB
Ultra Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
IR camera, Windows Hello
Sound
Stereo speakers, dual array microphone
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Multi-touch touchpad, gesture function, glass with chemical etched surface
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Miracast, dual stream (2x2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
6-cell Lithium Ion
67 Wh
AC Adapter
Input
Output
65 Watt, 5 / 9 / 10 / 12 / 15 / 20 V
Connections & Expansion
Interfaces Details
2 x USB 3.1 Gen 1 (charging) , 2 x USB-C 3.1 (supports Thunderbolt 3) , HDMI , Headphone/microphone combo jack
Software
Software Included
HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, Device Access Manager, HP Velocity, HP Manageability, HP Client Catalog, HP BIOS Config Utility, HP 3D DriveGuard, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP System Software Manager, HP Client Security Suite Gen3, HP BIOSphere Gen3, HP JetAdvantage, HP Wireless Wakeup, HP Management Integration Kit for Microsoft System Center Configuration Manager (free download), HP Sure Click, HP Driver Packs (free download)
Case Material
Aluminum
Integrated Options
Hood sensor
Security
Power-on password, Setup Password, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, HP Fast Charge, MIL-STD-810G tested, HP Sure Start Gen 3
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
USB-C power adapter
Localization
1.36 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
DVCJ HP 90W Smart AC Adapter In Stock £20.26
DVCJ HP 65W Smart AC Adapter In Stock £17.30
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
DVCJ HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site In Stock £124.94
Other bundles (3)
DVCJ HP USB-C To VGA Adapter In Stock £23.07
DVCJ HP USB Travel Mouse In Stock £9.23
DVCJ HP USB-C to HDMI 2.0 Adapter In Stock £47.25
