Comfortably carry your HP Elite x3 with the HP Elite x3 Silicone Case, which has an anti-slip finish and puts a layer of protection between your device and the real world.
Physical Characteristics
- Material: Silicone Polycarbonate
- Durability: Anti-slip
- Height: 6.5"
- Width: 3.4"
- Depth: 0.4"
Designed for: HP Elite x3
Unrestricted access
Easily slide the form-fitting case onto your device and retain access to its buttons, cameras, and connectors. -
Compatible with your ecosystem
Use the case with the HP Elite x3 Screen Protectors, Privacy Screen, Wireless Charger, and Desk Dock. -
World-class support
Get a one-year limited warranty.
- HP Silicone Case - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 8.675 cm x 16.435 cm x 1.12 cm
- 25.6 g
- Material
- Silicone
- 1-year warranty
- Designed For
- Elite x3
- 8.675 cm
- 16.435 cm
- 1.12 cm
- 25.6 g
- Material
- Silicone
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
- 1 year
- Designed For
- HP Elite x3
