Maximize your HP Elite x3's productivity with the HP Elite x3 Passive Stylus, which allows you to write naturally on the screen and navigate touchscreen activities.
Write or tap
Use the two-sided stylus to write onscreen, or interact with your virtual keyboard and touch applications. The top foam tip mimics your fingertip, and the 2 mm bottom tip helps ensure accurate, smooth handwriting. -
Take it with you
Attach the stylus to the included lanyard for easy carrying. -
World-class support
Rest easy with a one-year limited warranty.
- HP Passive Stylus - stylus for mobile phone
- Product Type
- Stylus
- Intended For
- Mobile phone
- Package Content
- Lanyard, 3 stylus tips
- Product Material
- Aluminium
- 0.95 cm
- Length
- 13.792 cm
- 12 g
- Black
- 1-year warranty
- Designed For
- Elite x3
- Product Type
- Stylus
- Intended For
- Mobile phone
- Package Content
- Product Material
- Aluminium
- 0.95 cm
- Length
- 13.792 cm
- 12 g
- Black
- 1 year
- Designed For
- HP Elite x3
