Boost your HP Elite x3 productivity with Windows Continuum and HP Workspace multi-screen and multi-app flexibility on the HP Elite x3 Lap Dock, which delivers a premium notebook experience with a nearly borderless 12.5" diagonal FHD screen, full-sized keyboard, and touchpad at a great value.
Multi-Task With Seamless Multi-Screen Flexibility
Talk, text and run mobile apps on your HP Elite x3 and work with Windows and corporate apps using Windows Continuum and HP Workspace on an ultra-narrow bezel 12.5" diagonal screen with the productivity boost of a large keyboard and touchpad.
A Premium Notebook Experience Without The Notebook Price Tag
Easily extend your HP Elite x3 with a large FHD screen and backlit, spill-resistant keyboard. The quiet, fanless, reinforced polycarbonate and stamped aluminum alloy design is ultrathin and ultralight to go wherever your day takes you.
Ready To Present And Accessorize
Show and share your work on an external display or projector with the micro HDMI connector, and add your accessories with two USB-C ports.
Power Through
Keep working with a generous 46.5 WHr battery, and get your HP Elite x3 back to full battery power with USB-C charging, even when the display is closed.
- HP Lap Dock - lapdock for mobile phone
- Product Type
- Lapdock
- Intended For
- Mobile phone
- Integrated Components
- Stereo speakers
- 28.9 cm x 20.1 cm x 13.8 cm
- 1 kg
- Designed For
- Elite x3
- Product Type
- Lapdock
- Intended For
- Mobile phone
- Stereo speakers
- Display
- LCD display - 12.5" - 1920 x 1080 - backlit
- Controls
- Touchpad, keyboard
- 28.9 cm
- 20.1 cm
- 13.8 cm
- 1 kg
- Connections
- 3 x USB - 24 pin Micro-USB-C , HDMI , Headphones
- Power Source
- USB
- Designed For
- HP Elite x3
