The HP Elite x3 is HP’s newest mobile device, carefully designed to combine PC power and productivity, tablet portability, and smartphone connectivity all in one handheld device.
Enhance productivity and mobility in the workplace with the Elite x3 and Windows Continuum1. Users can effortlessly switch between a handheld phablet, and a desktop PC or laptop experience when they dock to a larger display.
Experience the power and productivity of a PC, the portability of a tablet, and the connectivity of a smartphone in the palm of your hand with the HP Elite x3, HP's first built for business 3-in-1 device. It's designed to deliver simple and seamless access to your people, apps, and data.
The handheld HP Elite x3 is an easy and convenient way to work, in the office and on the go. Start a task on the go and finish at your desk without saving, syncing or restarting with the HP Elite x3, Microsoft Continuum, and optional docks, which allow you to work with a larger display. Crafted for business users, the HP Elite x3 is a robust device with powerful processing power, a long-life battery, dual biometric scanners, and dual SIM card slots. With HP Workspace, virtualize the business critical Windows x64 and x86 apps you rely on to get the job done.
- Built for business
- Enterprise security to reinvent the way you work
- A stellar multimedia experience
- The new mobile revolution
Superb manageability and value
Enable IT to reduce the combined footprint of devices and operating systems and drive mobile employee innovation with the HP Elite x3, which helps boost your return on your IT investment and employee satisfaction and productivity. -
Simplify your IT
Make device and app management easier than ever with a single device that leverages your existing Windows infrastructure and can replace a separate smartphone, tablet, and PC. -
Engineered to endure
The HP Elite x3 is a robust device thoughtfully designed to perform in even the most challenging environments. It has passed MIL-STD 810G testing and is IP67 rated for dust and water resistance. -
Optimized for business collaboration
Enjoy clear conversations with premium audio by B&O PLAY, dual front-facing speakers, active noise cancellation microphones, and an 8 MP front-facing camera that's great for Skype for Business conference calls. -
A high level of security
Help secure your data and apply corporate security policies with integrated hardware and software encryption, and iris and fingerprint authentication. -
Turn every room into a screening room
Project your slide show, video, product demo, and more to a larger screen through the integrated Microsoft Miracast technology.
- HP Elite x3 graphite with chrome - 4G smartphone - 64 GB - GSM - with HP Desk Dock
- Product Type
- 4G smartphone
- Display
- OLED display - 2560 x 1440 pixels - 5.96" - 494 ppi - AMOLED - Corning Gorilla Glass 4 (scratch resistant glass)
- Processor
- Qualcomm Snapdragon 820 2.15 GHz (quad-core) - 64-bit
- Graphics Accelerator
- Qualcomm ADRENO 530
- Memory
- RAM 4 GB / 64 GB
- Supported Memory Card
- microSDXC slot - up to 2 TB
- Operating System
- Windows 10
- Main Camera
- 16 Megapixel focus: automatic
- Front Camera
- 8 Megapixel f/2.2
- Service Provider
- Not specified
- SIM Card
- Nano SIM
- Wireless Interface
- NFC, Bluetooth, Wi-Fi 5
- Security Devices
- Fingerprint reader
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Wireless Charging Standards
- WPC, PMA, Qi
- Bundled with
- HP Desk Dock
- Protection
- Dustproof, waterproof
- Graphite with chrome
- 83.5 mm x 7.8 mm x 161.8 mm
- 194 g
- 1-year warranty
- Product Type
- Smartphone
- Form Factor
- Touch
- Protection
- 83.5 mm
- 7.8 mm
- 161.8 mm
- 194 g
- Body Colour
- Bundled with
- HP Desk Dock
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Windows 10
- Navigation
- GPS
- SIM Card Type
- Nano SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE, LTE Advanced
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 4G LTE Band
- Band 1, Band 3, Band 19, Band 20, Band 26, Band 28, Band 38, Band 39, Band 40
- 4G LTE Frequency
- FDD 2100, FDD 1800+, FDD 800 upper, FDD 800 DD, FDD 850+, FDD 700 APT, TDD 2600, TDD 1900, TDD 2300
- NFC, Bluetooth 4.0, IEEE 802.11a/b/g/n/ac
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, digital compass, gyro sensor, hall sensor, pressure sensor
- Security Devices
- Additional Features
- Wi-Fi Miracast, Audio by B&O PLAY, Snapdragon Audio + support, 3 integrated omni-directional microphones with HP Noise Cancellation Software, ENERGY STAR certified
- Clock Speed
- 2.15 GHz
- Processor Core Qty
- Quad-core
- 64-bit Architecture
Graphics System
- RAM
- 4 GB
- Internal Memory Capacity
- 64 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 2 TB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Lens Aperture
- F/2.2
- Video Resolutions
- 1920 x 1080 (1080p)
Main Camera
- Sensor Resolution
- 16 Megapixel
- Focus Adjustment
- Automatic
- Light Source
- LED light
- Video Resolutions
Display
- OLED display
- Technology
- AMOLED
- Diagonal Size
- 5.96"
- Display Resolution
- Display Format
- QHD
- Pixel Density
- 494 ppi
- Protection
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Technology
- Lithium polymer
- Capacity
- 4150 mAh
- Wireless Charging
- WPC, PMA, Qi
- MIL-STD 810G, IP67
- Included Accessories
- Headset, power adapter
- Limited warranty - parts and labour - 1 year
