Experience beauty and power that goes beyond expectations with the HP Elite x2 1012. It's a tested-tough 2 in 1 with precision-crafted keyboards, and a thin and light powerhouse designed to the exacting standards of the enterprise.
The tools you need to succeed
Start, work, and transition between modes easily with Windows 10 Pro. -
A great mobile productivity keyboard
Superb typing experience, with high performance keyboards for productivity on the go with the HP Elite x2 1012 keyboard options. -
Capture spontaneous ideas
Create with the precision and accuracy of industry preferred Wacom technology in the HP Active Pen with App Launch. -
Performance to get the job done
The quiet fanless design and 10 hours of battery life lets you work, surf, and connect with colleagues. -
Speedy transfers
Charge devices, transfer data quickly, and connect to 4k devices with the USB-C port with Thunderbolt technology. -
Connect and collaborate in style
Conduct virtual meetings with Audio by Bang & Olufsen, HP Noise Reduction Software and front/back camera.
- HP Elite x2 1012 G1 - 12" - Intel Core m7 - 6Y75 - vPro - 8 GB RAM - 512 GB SSD - 4G LTE - UK
- Product Type
- Tablet - with detachable keyboard
- Operating System
- Win 10 Pro 64-bit - English
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core m7 (6th Gen) - 6Y75 / 1.2 GHz, up to 3.1 GHz / 4 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 512 GB SSD
- Display
- 12" LED backlight touchscreen 1920 x 1280 / WUXGA+
- Graphics
- Intel HD Graphics 515
- Input Device
- Keyboard, digital pen, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Wireless Broadband (WWAN)
- 4G LTE
- Service Provider
- Service not included
- Battery
- 4-cell - up to 10.25 hours
- Ambient light sensor, proximity sensor, hall sensor
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Dimensions (WxDxH) - tablet
- 30 cm x 21.35 cm x 0.805 cm
- 820 g
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core m7 (6th Gen) 6Y75 / 1.2 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 512 GB SSD M.2 SATA 6Gb/s
Display
- 12" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1920 x 1280 (WUXGA+)
- Widescreen
- Image Aspect Ratio
- 3:2
- Image Brightness
- 340 cd/m²
- Ultra Slim Design, Direct Bonding technology, Full HD ultra wide-viewing angle (UWVA) BrightView eDP, Corning Gorilla glass 4
Audio & Video
- Graphics Processor
- Camera
- Yes - 1080p
- Resolution
- 5 Megapixel (rear), 2 Megapixel (front)
- Camera Features
- 1080p Full HD movie recording, low light enhancement, rear camera with flash
- Sound
- Stereo speakers, two microphones
- Audio Features
- Output: noise-cancellation technology, Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Volume control, touchpad with gesture support, gesture function
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- PCI Express Mini Card (M.2)
- Intel Wireless Display (WiDi)
- IEEE 802.11i, Wi-Fi CERTIFIED
- Generation
- 4G
- Technology
- GPRS, EDGE, CDMA 2000 1X EV-DO Rev. A, LTE, DC-HSPA+
- Service Provider
Navigation
- Receiver
- A-GPS/GPS/GLONASS
- Technology
- 4-cell lithium polymer
- Installed Qty
- 1
- Max Supported Qty
- 1
- Capacity
- 40 Wh
- Run Time
- Up to 10.25 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 5 / 12 / 15 V, 1.4 A
Connections & Expansion
- Slots
- 1 x Micro-SIM card (1 free)
- Interfaces Details
- USB-C (supports Thunderbolt 3) , USB 3.0 , Headphone/microphone combo jack , Dock
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Foxit PhantomPDF Express, Intel Wireless Display, Windows Defender, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Driver Packs, LANDesk Management Suite (free download), HP CIK for Microsoft SCCM (free download), HP Touchpoint Manager, Wacom Pen App, HP Noise Reduction Software
- Integrated Options
- Dockable
- Security
- HP DuraKeys, HP SpareKey, Accelerometer, built-in adjustable tilt stand, HP BIOS Protection, magnetometer, gyroscope, microphone with echo and noise-cancellation, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- Power adapter, keyboard, HP Active Pen, HP Elite x2 1012 G1 Travel Keyboard
- Localization
- 820 g
- Dimensions (WxDxH) / Weight Details
- 30 cm x 21.35 cm x 13.45 cm / 1.205 kg - tablet with keyboard , 30 cm x 21.93 cm x 0.61 cm / 385 g - keyboard dock
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 240 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 1.043 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 3.5 g @ RMS (random)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
HP USB-C mini Dock - Docking Station - USB-C - VGA, HDMI - GigE | In Stock | £35.26 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £135.82 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £188.99 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site | In Stock | £91.80 |
Other bundles (6)
HPE DisplayPort to HDMI Adapter | In Stock | £13.44 |
HPE HP DisplayPort to DVI Adapter | In Stock | £17.23 |
HPE DisplayPort to VGA Adapter | In Stock | £16.40 |
HP USB-C To VGA Adapter | In Stock | £22.68 |
HP USB Travel Mouse | In Stock | £10.58 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
