HP Elite x2 1012 G1 Intel Core M5-6Y57 8GB 256GB SSD 12" Windows 10 Professional 64-bit
Quicklinx: BTXZWS00 Mfr#: L5H09EA#ABU
  • IEEE 802.11n
Experience beauty and power that goes beyond expectations with the HP Elite x2 1012. It's a tested-tough 2 in 1 with precision-crafted keyboards, and a thin and light powerhouse designed to the exacting standards of the enterprise.
  • The tools you need to succeed
    Start, work, and transition between modes easily with Windows 10 Pro.
  • A great mobile productivity keyboard
    Superb typing experience, with high performance keyboards for productivity on the go with the HP Elite x2 1012 keyboard options.
  • Capture spontaneous ideas
    Create with the precision and accuracy of industry preferred Wacom technology in the HP Active Pen with App Launch.
  • Performance to get the job done
    The quiet fanless design and 10 hours of battery life lets you work, surf, and connect with colleagues.
  • Speedy transfers
    Charge devices, transfer data quickly, and connect to 4k devices with the USB-C port with Thunderbolt technology.
  • Connect and collaborate in style
    Conduct virtual meetings with Audio by Bang & Olufsen, HP Noise Reduction Software and front/back camera.
HP Elite x2 1012 G1 - 12" - Intel Core m5 - 6Y57 - vPro - 8 GB RAM - 256 GB SSD - 4G LTE - UK
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit - English
Platform Technology
Intel vPro Platform
Intel Core m5 (6th Gen) - 6Y57 / 1.1 GHz, up to 2.8 GHz / 4 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Display
12" LED backlight touchscreen 1920 x 1280 / WUXGA+
Graphics
Intel HD Graphics 515
Input Device
Keyboard, digital pen, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
Wireless Broadband (WWAN)
4G LTE
Service Provider
Service not included
4-cell - up to 10.25 hours
Ambient light sensor, proximity sensor, hall sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Dimensions (WxDxH) - tablet
30 cm x 21.35 cm x 0.805 cm
820 g
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core m5 (6th Gen) 6Y57 / 1.1 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Platform Technology
Intel vPro Platform
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
12" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1280 (WUXGA+)
Widescreen
Image Aspect Ratio
3:2
Image Brightness
340 cd/m²
Ultra Slim Design, Direct Bonding technology, Full HD ultra wide-viewing angle (UWVA) BrightView eDP, Corning Gorilla glass 4
Audio & Video
Graphics Processor
Camera
Yes - 1080p
Resolution
5 Megapixel (rear), 2 Megapixel (front)
Camera Features
1080p Full HD movie recording, low light enhancement, rear camera with flash
Sound
Stereo speakers, two microphones
Audio Features
Output: noise-cancellation technology, Bang & Olufsen Audio
Input
Keyboard Backlight
Keyboard Layout
Volume control, touchpad with gesture support, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
PCI Express Mini Card (M.2)
Intel Wireless Display (WiDi)
IEEE 802.11i, Wi-Fi CERTIFIED
Generation
4G
GPRS, EDGE, CDMA 2000 1X EV-DO Rev. A, LTE, DC-HSPA+
Controller
M.2 Card
Service Provider
Navigation
Receiver
A-GPS/GPS/GLONASS
4-cell lithium polymer
Installed Qty
1
Max Supported Qty
1
40 Wh
Run Time
Up to 10.25 hours
AC Adapter
Input
Output
45 Watt, 5 / 12 / 15 V, 1.4 A
Connections & Expansion
Slots
1 x Micro-SIM card (1 free)
Interfaces Details
USB-C (supports Thunderbolt 3) , USB 3.0 , Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Foxit PhantomPDF Express, Intel Wireless Display, Windows Defender, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Driver Packs, LANDesk Management Suite (free download), HP CIK for Microsoft SCCM (free download), HP Touchpoint Manager, Wacom Pen App, HP Noise Reduction Software
Integrated Options
Dockable
Security
HP DuraKeys, HP SpareKey, Accelerometer, built-in adjustable tilt stand, HP BIOS Protection, magnetometer, gyroscope, microphone with echo and noise-cancellation, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
Power adapter, keyboard, HP Active Pen, HP Elite x2 1012 G1 Travel Keyboard
Localization
820 g
Dimensions (WxDxH) / Weight Details
30 cm x 21.35 cm x 13.45 cm / 1.205 kg - tablet with keyboard , 30 cm x 21.93 cm x 0.61 cm / 385 g - keyboard dock
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
BTXZ HP USB-C mini Dock - Docking Station - USB-C - VGA, HDMI - GigE In Stock £33.61
BTXZ HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £147.06
BTXZ HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £206.71
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
BTXZ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £94.03
Other bundles (8)
BTXZ HPE DisplayPort to HDMI Adapter In Stock £13.44
BTXZ HPE HP DisplayPort to DVI Adapter In Stock £17.23
BTXZ HPE DisplayPort to VGA Adapter In Stock £16.34
BTXZ HP USB-C To VGA Adapter In Stock £22.68
BTXZ HP USB Travel Mouse In Stock £10.14
BTXZ HP X4000b Bluetooth Mouse In Stock £28.71
BTXZ HP USB-C to DisplayPort Adapter In Stock £23.53
BTXZ HP USB-C to HDMI 2.0 Adapter In Stock £47.06
