HP Elite x2 1012 G1 Intel Core M5-6Y54 4GB 128GB SSD 12" Windows 10 Professional 64-bit
Quicklinx: BTXSWS00 Mfr#: L5H02EA#ABU
  • IEEE 802.11n
Experience beauty and power that goes beyond expectations with the HP Elite x2 1012. It's a tested-tough 2 in 1 with precision-crafted keyboards, and a thin and light powerhouse designed to the exacting standards of the enterprise.
  • The tools you need to succeed
    Start, work, and transition between modes easily with Windows 10 Pro.
  • A great mobile productivity keyboard
    Superb typing experience, with high performance keyboards for productivity on the go with the HP Elite x2 1012 keyboard options.
  • Capture spontaneous ideas
    Create with the precision and accuracy of industry preferred Wacom technology in the HP Active Pen with App Launch.
  • Performance to get the job done
    The quiet fanless design and 10 hours of battery life lets you work, surf, and connect with colleagues.
  • Speedy transfers
    Charge devices, transfer data quickly, and connect to 4k devices with the USB-C port with Thunderbolt technology.
  • Connect and collaborate in style
    Conduct virtual meetings with Audio by Bang & Olufsen, HP Noise Reduction Software and front/back camera.
HP Elite x2 1012 G1 - 12" - Intel Core m5 - 6Y54 - 4 GB RAM - 128 GB SSD
Tablet - no keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Core m5 (6th Gen) - 6Y54 / 1.1 GHz, up to 2.7 GHz / 4 MB Cache
4 GB LPDDR3 (provided memory is soldered)
Storage
128 GB SSD
Display
12" LED backlight touchscreen 1920 x 1280 / WUXGA+
Graphics
Intel HD Graphics 515
Input Device
Digital pen
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
4-cell - up to 10.25 hours
Ambient light sensor, proximity sensor, hall sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
30 cm x 21.35 cm x 0.805 cm
840 g
Environmental Standards
- ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core m5 (6th Gen) 6Y54 / 1.1 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
128 GB SSD M.2 SATA 6Gb/s
Display
12" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1280 (WUXGA+)
Widescreen
Image Aspect Ratio
3:2
Image Brightness
340 cd/m²
Ultra Slim Design, Direct Bonding technology, Full HD ultra wide-viewing angle (UWVA) BrightView eDP, Corning Gorilla glass 4
Audio & Video
Graphics Processor
Camera
Yes - 1080p
Resolution
5 Megapixel (rear), 2 Megapixel (front)
Camera Features
1080p Full HD movie recording, low light enhancement, rear camera with flash
Sound
Stereo speakers, two microphones
Audio Features
Output: noise-cancellation technology, Bang & Olufsen Audio
Input
Digital pen
Volume control
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
Intel Wireless Display (WiDi)
IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
Installed Qty
1
Max Supported Qty
1
40 Wh
Run Time
Up to 10.25 hours
AC Adapter
Input
Output
45 Watt 1.4 A
Connections & Expansion
Interfaces Details
USB-C (supports Thunderbolt 3) , USB 3.0 , Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Foxit PhantomPDF Express, Intel Wireless Display, Windows Defender, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Driver Packs, LANDesk Management Suite (free download), HP CIK for Microsoft SCCM (free download), HP Touchpoint Manager, Wacom Pen App, HP Noise Reduction Software
Integrated Options
Dockable
Security
HP DuraKeys, HP SpareKey, built-in leg stand, Accelerometer, HP BIOS Protection, magnetometer, gyroscope, microphone with echo and noise-cancellation, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
Power adapter, HP Active Pen
Localization
840 g
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
BTXS HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £109.31
BTXS HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £138.07
Other bundles (3)
BTXS HP USB-C To VGA Adapter In Stock £22.09
BTXS HP USB Travel Mouse In Stock £9.39
BTXS HP USB-C to HDMI 2.0 Adapter In Stock £46.71
