HP Elite x2 1011 G1 Intel Core M 5Y10c 4GB 256GB 11.6" Windows 10 Professional 64-bit
Quicklinx: BPKNWS00 Mfr#: L5G64EA#ABU
  • IEEE 802.11n
  • Bluetooth 4.0
Tablet or Ultrabook How about both? The one device you need for wherever business takes you. This highly mobile device with unmatched durability comes fully equipped with HP's leading security and manageability.
  • The tools you need to succeed
    Make edits with the Wacom pen and enjoy stability from the reflex hinge on the optional keyboard.
  • Built-in durability
    Enjoy a premium durable design engineered to undergo MIL-STD 810G testing and HP's Total Test Process.
  • Connect and collaborate
    Organize virtual meetings with optional Qualcomm GOBI 4G LTE WWAN and two cameras.
  • More convenience, less to manage
    Reduce management time thanks to the 2-in-1 design and HP Client Management Solutions and Intel vPro.
  • In it for the long haul
    Benefit from the stability of a long lifecycle and global series support.
  • Cloud-based IT management made simple
    Manage data, security, and devices from a single cloud-based solution with HP Touchpoint Manager.
HP Elite x2 1011 G1 - 11.6" - Intel Core M - 5Y10c - 4 GB RAM - 256 GB SSD - UK
Tablet - with keyboard dock
Operating System
Win 10 Pro 64-bit - English
Intel Core M 5Y10c / 800 MHz, up to 2 GHz / 4 MB Cache
4 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Display
11.6" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 5300
Input Device
Keyboard, ForcePad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, 802.11ad (WiGig)
2-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Dimensions (WxDxH) - tablet
29.8 cm x 19.27 cm x 1.07 cm
780 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 1 year
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
2 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1600 MHz
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
11.6" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Ultra Slim Design, Full HD BrightView, Corning Gorilla glass 3, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1080p
Resolution
5 Megapixel (rear), 2 Megapixel (front)
Camera Features
1080p Full HD movie recording, low light enhancement
Sound
Stereo speakers, stereo microphone
Codec
Realtek ALC3228
High Definition Audio, DTS Studio Sound
Input
Keyboard, ForcePad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Tri-Band Wireless-AC 17265 - M.2 Card
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
2-cell lithium polymer
Installed Qty
2
Max Supported Qty
2
33 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Slots
1 x Micro-SIM card (1 free)
DisplayPort (on keyboard dock) , 2 x USB 3.0 (on keyboard dock) , Dock (on keyboard dock) , Headphone/microphone combo jack (on keyboard dock) , Dock , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
LANDesk Management Suite, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Client Security, HP Systems Software Manager (free download), HP PageLift, HP File Sanitizer, Drive Encryption, HP Client Catalog, Absolute Persistence, HP Driver Packs, HP BIOS Config Utility, HP CIK for Microsoft SCCM, HP Device Access Manager, HP Touchpoint Manager, HP 3D DriveGuard
Dockable
Security
HP 3D DriveGuard, HP SpareKey, HP File Sanitizer, HP BIOS Protection, microphone with echo and noise-cancellation, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, HP Roaming Alert, 1 USB 3.0 charging port
Power adapter
RoHS, WEEE
Localization
780 g
Dimensions (WxDxH) / Weight Details
29.8 cm x 19.27 cm x 1.07 cm / 780 g - tablet , 29.8 cm x 20.61 cm x 2.08 cm / 1.54 kg - tablet with keyboard
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
