HP Elite USB-C Docking Station 90W
Quicklinx: CTBXWS00 Mfr#: Z9R42AA#ABU
Maximize mobile productivity in the office with one USB-C cable connection to the enterprise-ready HP Elite USB-C Dock. It delivers device charging to your HP 3-in-1, detachable or notebook, supports up to three displays, and enables connectivity to your wired network and accessories.
HP Elite USB-C Dock - Docking station - (USB-C) - GigE - 90 Watt - GB
  • Multi-task like a pro
    Connect the dock's cable to your device's USB-C port to charge it while you work, access your wired network, and connect to one 4K or up to three FHD displays, plus your accessories, through two DisplayPort , HDMI, RJ-45, and five USB ports.
  • Built for the enterprise
    Get optimal security from a driver-free dock that has no internal flash memory. It supports network manageability with integrated Wake on LAN, PXE boot, and 802.1x authentication, and can be physically secured with a lock slot.
  • World-class support
    Rest easy with a one-year limited warranty.
HP Elite USB-C Dock - docking station - USB-C - HDMI, 2 x DP - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI, 2 x DP
19.8 cm x 6.9 cm x 2.2 cm
355 g
English / United Kingdom
Gigabit Ethernet
Power adapter 90 Watt Power Provided
1-year warranty
Chromebook 14 G4; Elite x2 1012 G1, 1012 G2; EliteBook Folio G1; EliteBook x360 1030 G2 Notebook; Pro x2 612 G2
Docking station
19.8 cm
6.9 cm
2.2 cm
355 g
Enclosure Colour
Gigabit Ethernet
IEEE 802.1x
2 x USB-C , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x headphone/microphone combo jack , 2 x USB 2.0 - 4 pin USB Type A , 1 x audio / video - HDMI - 19 pin HDMI Type A , 2 x audio / video - DisplayPort - 20 pin DisplayPort , 1 x network - RJ-45
1 x USB-C cable - 1 m
Security lock slot (cable lock sold separately), wake on LAN, Preboot Execution Environment (PXE) support
Power adapter
Power Provided
90 Watt
Windows 10, Windows 10 Mobile
Limited warranty - 1 year
HP Chromebook 14 G4 , HP Elite x2 1012 G1, 1012 G2 , HP EliteBook Folio G1 , HP EliteBook x360 1030 G2 Notebook , HP Pro x2 612 G2
