Change the dynamics of the room with the meticulously crafted, ultra-light HP Elite Dragonfly featuring HP Wolf Security for Business. This beautifully designed, laptop provides a stunning collaboration experience powered by HP Presence with AI-driven crystal-clear audio and an HD display. Drive productivity with a powerful Intel Core processor, a Wi-Fi 6E connection, and contextual intelligence.
Windows 11
Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology. -
Fast and efficient wireless LAN
The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6. -
Browse confidently
Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
- HP Elite Dragonfly G3 Notebook - 13.5" - Intel Core i7 - 1255U - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 11 Pro - English
- Processor
- Intel Core i7 (12th Gen) - 1255U / 1.7 GHz, up to 4.7 GHz / 12 MB Cache
- Memory
- 16 GB LPDDR5 (provided memory is soldered)
- Storage
- 512 GB SSD - NVMe, TLC
- Display
- 13.5" WLED touchscreen 1920 x 1280 / WUXGA+ @ 60 Hz
- Graphics
- Intel Iris Xe Graphics
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 5.2, 802.11a/b/g/n/ac/ax (Wi-Fi 6E)
- Battery
- 6-cell - up to 19.5 hours
- Ambient light sensor, HP Tamper Lock, ambient colour sensor
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Slate blue
- 29.74 cm x 22.04 cm x 1.64 cm
- 990 g
- Localisation
- Environmental Standards
- TCO Certified Notebooks 9, ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Operating System
- Windows 11 Pro - English
Processor / Chipset
- CPU
- Intel Core i7 (12th Gen) 1255U / 1.7 GHz
- Max Turbo Speed
- 4.7 GHz
- Number of Cores
- 10-core
- Cache
- L3 - 12 MB
- Intel Turbo Boost Technology
- RAM
- 16 GB (provided memory is soldered)
- Technology
- LPDDR5 SDRAM - non-ECC
- Speed
- 4800 MHz
- Rated Speed
- 4800 MHz
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC)
Display
- 13.5" - IPS
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Resolution
- 1920 x 1280 (WUXGA+)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 100% sRGB
- Micro Edge, Low Blue Light technology, Low Power, HP Eye Ease, WUXGA+ ultra wide-viewing angle (UWVA) anti-glare eDP +PSR
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 5 Megapixel
- Camera Features
- HP Camera Privacy Key, MIPI-RAW Infrared, HP Auto Frame
- Sound
- Dual array microphone
- Codec
- Realtek ALC3315
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Multi-touch clickpad, gesture function, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wi-Fi 6E AX 211 - PCI Express Mini Card (M.2)
- Miracast, dual stream (2x2), CNVi
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 6-cell lithium polymer
- Capacity
- 68 Wh
- Run Time
- Up to 19.5 hours
AC Adapter
- Input
- AC 115/230 V (50/60 Hz)
- Output
- 65 Watt, 5 / 9 / 12 / 15 / 20 V, 8 A
Connections & Expansion
- Interfaces Details
- 2 x USB4 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (charging) , HDMI , Headphone/microphone combo jack
Software
- Software Included
- HP Support Assistant, HP Power Manager, HP Hotkey Support, HP Secure Erase, HP Client Catalogue (free download), HP PC Hardware Diagnostics, HP Manageability & Integration Kit (free download), HP Notifications, HP Connection Optimizer, HP Sure Click, HP Privacy Settings, HP Cloud Recovery, HP Sure Sense, HP Sure Admin, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, HP Wake on WLAN, myHP, HP Image Assistant Gen5 (free download), HP Client Security Manager Gen7, HP Easy Clean, HP Smart Support, HP Quick Touch, HP Sure Recover Gen5, HP Sure Run Gen5, HP Sure Start Gen7, HP Driver Packs (free download)
- Slate blue
- Integrated Options
- Security
- BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, HP Fast Charge, BIOS Update via Network, MIL-STD-810H tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- HP 65 Watt nPFC Slim USB-C AC Adapter
- CSA, UL, VCCI, BSMI, SABS, CCC, FIPS 140-2 Level 2, FCC, RoHS, WEEE, ICES, Common Criteria EAL4+, KC, EAC, CIT, IEEE 1680, ICCP, AUS/NZ, BNCI
- Localization
- 990 g
Sustainability Information
- TCO Certified
- - TCO Certified Notebooks 9
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 1.043 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 3.5 g @ RMS (random)
Essential Accessories (9)
Get more from your purchase from one of our essential accessories
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £116.78 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £145.96 |
HP Thunderbolt Dock G4 - HDMI, 2 x DP, Thunderbolt, USB-C - 1GbE, 2.5GbE | In Stock | £144.80 |
HP USB-C Power Adapter - 65 Watt | In Stock | £57.16 |
HP Prelude Top Load 15.6" Notebook Carrying Case | In Stock | £10.35 |
HP Thunderbolt Dock G4 - USB-C / Thunderbolt 4 - HDMI, 2 x DP, Thunderbolt, USB-C - 1GbE, 2.5GbE | In Stock | £193.84 |
HP USB-C LC Power Adapter - 65 Watt | In Stock | £15.28 |
HP Nano - Security Cable Lock | In Stock | £15.92 |
HP Renew Business - Notebook carrying shoulder bag - 17.3" | In Stock | £19.13 |
Other bundles (65)
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £10.91 |
HP USB G2 Stereo Headset | In Stock | £20.44 |
HP 128 Wired Mouse | In Stock | £8.56 |
HP 455 Programmable Keyboard - Wireless - UK | In Stock | £26.46 |
HP USB-C to RJ45 Adapter G2 | In Stock | £13.20 |
Poly Voyager Focus 2 UC-M C USB-A WW | In Stock | £99.99 |
Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter | In Stock | £240.58 |
Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A | In Stock | £234.68 |
Poly P5 1080P HD Webcam | In Stock | £36.52 |
Poly Voyager 4320 UC V4320-M C USB-A WW | In Stock | £124.75 |
Poly Voyager 4320 UC V4320 C USB-C WW | In Stock | £103.93 |
Poly DA85-M Sound Card | In Stock | £53.34 |
Poly Voyager Focus 2 UC-M USB-A with Stand | In Stock | £108.52 |
Poly TRIO C60 EXPANSION MICROPHONES | In Stock | £134.01 |
Poly Blackwire C3225 USB-A Headset | In Stock | £51.43 |
Poly EncorePro HW520 Stereo Headset (Noise Cancelling) | In Stock | £81.71 |
Poly DA85 Headset Cable - USB-C to Quick Disconnect | In Stock | £53.34 |
Poly EncorePro HW510 Mono Headset (N/C) | In Stock | £86.11 |
Poly Voyager 4320 UC V4320-M C USB-A CS WW | In Stock | £108.73 |
Poly Voyager 4320 UC V4320-M C USB-C WW | In Stock | £98.60 |
Poly Voyager 4320 UC V4320 C USB-A CS WW | In Stock | £131.93 |
Poly Voyager 4310 UC V4310-M C USB-A WW | In Stock | £110.75 |
Poly Voyager 4320 UC V4320 C USB-C CS WW | In Stock | £119.34 |
Poly Voyager 4320 UC V4320-M C USB-C CS WW | In Stock | £110.60 |
Poly Voyager 4310 UC V4310-M C USB-A CS WW | In Stock | £121.68 |
Poly Voyager 4320 UC V4320 C USB-A WW | In Stock | £97.00 |
Poly Voyager 4310 UC V4310 C USB-A WW | In Stock | £113.52 |
Poly Voyager 4310 UC V4310 C USB-A CS WW | In Stock | £121.68 |
Poly Sync 10 SY10-M USB-A/C WW | In Stock | £60.31 |
Poly EncorePro 525 USB EP525 USB-A Headset | In Stock | £84.71 |
Poly EncorePro HW510 Mono Headset (VT) | In Stock | £73.73 |
Poly Voyager Focus 2 UC-M USB-C Headset with Stand | In Stock | £141.12 |
Poly Sync 40 SY40-M WW | In Stock | £139.01 |
Poly EncorePro 525 USB EP525-M USB-A Headset | In Stock | £86.88 |
Poly Voyager Focus 2 UC USB-A Headset with Stand | In Stock | £143.47 |
Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C | In Stock | £92.95 |
Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified | In Stock | £34.67 |
Poly Poly Blackwire 3320 Stereo USB-C/A Adapter | In Stock | £33.49 |
Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C | In Stock | £75.19 |
Poly Spare BT700 Bluetooth USB Adapter | In Stock | £58.49 |
Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified | In Stock | £49.32 |
Poly Wireless Headset System Base for Bluetooth headset - for Poly Voyager | In Stock | £91.05 |
HyperX Pulsefire Core Gaming Mouse | In Stock | £27.07 |
HyperX Pulsefire Mat Gaming Mouse Pad | In Stock | £12.57 |
HP OMEN 27" Full HD 165Hz Gaming Monitor | In Stock | £145.60 |
Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter | In Stock | £65.77 |
Poly Blackwire 3310 headset - on-ear - wired - USB-A - black | In Stock | £28.00 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £31.11 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £29.33 |
Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter | In Stock | £28.00 |
Poly EncorePro 515-M headset - on-ear - wired - USB-A - black | In Stock | £75.67 |
HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £320.60 |
Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black | In Stock | £81.56 |
Poly EncorePro 530 - headset - Quick Disconnect | In Stock | £81.56 |
HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor | In Stock | £153.30 |
Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams | In Stock | £121.68 |
Poly EncorePro HW520D - headset - Quick Disconnect | In Stock | £107.03 |
HP E24m G4 23.8" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor | In Stock | £211.74 |
Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £54.64 |
HP 230 - keyboard and mouse set - UK Input Device | In Stock | £36.54 |
HP 715 - mouse - multi-device, rechargeable - Bluetooth 3.0, 2.4 GHz - black | In Stock | £51.11 |
HP E27 G5 27" 1920x1080 5ms HDMI DisplayPort USB IPS LED Monitor | In Stock | £127.93 |
