Keep your momentum moving with the HP Elite c1030 Chromebook. It has a durable, ultraportable design, enhanced wireless connectivity, and a built-in fingerprint sensor for fast logins for your work on the cloud and on the go.
Simplify deployments
Get a low-maintenance experience with the automatic software updates and virus protection of the Chrome OS. -
Universal connectivity and charging with USB-C
Use the USB-C port to access and charge your USB-C accessories from your Chromebook or charge your Chromebook from any USB-C adapter. -
Enhanced design elements
Help prevent degradation, water intrusion, and tampering with a keyboard that resists picks, minor spills, and key removal. -
Apps and content for expanded learning
Take learning in new directions with access to the Google Play Store and Android apps, which include thousands of instantly shareable and easily manageable innovative education apps.
- HP Elite c1030 Chromebook - 13.5" - Intel Core i7 - 10610U - vPro - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Chromebook - flip design
- Operating System
- Chrome OS - English
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i7 (10th Gen) - 10610U / 1.8 GHz, up to 4.9 GHz / 8 MB Cache
- Memory
- 8 GB DDR4 (8 GB (soldered))
- Storage
- 256 GB SSD - NVMe, HP Value
- Display
- 13.5" WLED touchscreen 1920 x 1280 / WUXGA+
- Graphics
- Intel UHD Graphics
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.1
- Battery
- 4-cell
- Security
- Google Security Chip H1, fingerprint reader
- 29.5 cm x 21.7 cm x 1.61 cm
- 1.33 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Google Chrome OS - English
Processor / Chipset
- CPU
- Intel Core i7 (10th Gen) 10610U / 1.8 GHz
- Max Turbo Speed
- 4.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (8 GB (soldered))
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
Storage
- Main Storage
- 256 GB SSD M.2 2230 PCIe 3.0 x4 - NVM Express (NVMe), HP Value
Display
- 13.5"
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Resolution
- 1920 x 1280 (WUXGA+)
- Widescreen
- Image Aspect Ratio
- 3:2
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 72% NTSC
- BrightView, narrow-bezel design, 72% NTSC colour gamut
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- Privacy camera
- Sound
- Stereo speakers, dual array microphone
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Volume control, spill-resistant, multi-gesture clickpad
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - PCI Express Mini Card (M.2)
- Miracast, dual stream (2x2), MU-MIMO
- IEEE 802.11d, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v
- Technology
- 4-cell lithium polymer
- Capacity
- 50 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 5 / 9 / 12 / 15 V
Connections & Expansion
- Interfaces Details
- 2 x USB-C 3.2 Gen 1 (Power Delivery/data/video) , USB 3.2 Gen 1 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Google One (100 GB Cloud Storage) (free for 1 year)
- Case Material
- Aluminum
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter
- UL, VCCI, BSMI, SABS, CCC, FCC, ICES, KC, EAC, RCM, ICCP
- Localization
- 1.33 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 90%
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 240 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 1.043 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 3.5 g @ RMS (random)
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
HP 65W Smart AC Adapter | In Stock | £17.30 |
Other bundles (3)
HP USB-C To VGA Adapter | In Stock | £23.07 |
HP USB Travel Mouse | In Stock | £9.28 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £47.48 |
