HP Elite 600 DM G9 Intel Core i5-13500 8GB 256GB SSD Windows 11 Professional
Quicklinx: HGH5WS00 Mfr#: 883X2EA#ABU
  • Core i5
  • IEEE 802.11n
The HP Elite Mini 600 Desktop PC delivers the performance needed to for your enterprise workload, while still being small enough to allow you to take it with you between the home and the office. Equipped with a powerful Intel Processor, DDR5 memory, and smart deployment options, this is the right PC for desktop users needing flexibility in where they work.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • Security is your top priority
    The HP Wolf Pro Security Edition provides preconfigured enterprise-level PC protection for small and medium sized businesses.
  • Automatic recovery from firmware attacks
    Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen7 automatically recovers the BIOS from malware, rootkits, or corruption.
  • Work without interruption
    Keep productivity high and downtime low with the fully integrated and automated features of the HP BIOSphere Gen6 firmware ecosystem. Your PCs have extra protection thanks to automatic updates and security checks.
  • Browse confidently
    Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
  • Simple PC management
    Spend less time and get right to the updates you need with HP Support Assistant.
HP Elite 600 G9 - mini Core i5 13500T 1.6 GHz - 8 GB - SSD 256 GB - UK - with HP Wolf Pro Security Edition (1 year)
Personal computer - mini
Intel Core i5 (13th Gen) 13500T / 1.6 GHz (up to 4.6 GHz, (14-core)
Processor Main Features
Intel Turbo Boost Technology
Cache Memory
24 MB L3 Cache
Cache Per Processor
24 MB
RAM
8 GB (installed) / 64 GB (max) - DDR5 SDRAM
Hard Drive
SSD 256 GB - PCI Express - M.2 - NVM Express (NVMe)
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 770
Audio Output
Stereo
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Wi-Fi 6E, Bluetooth 5.3
Keyboard
(50/60 Hz)
OS Provided
Windows 11 Pro
Software Included
HP Support Assistant, HP PC Hardware Diagnostics UEFI, HP Secure Erase, HP Client Catalogue (free download), HP Setup Integrated OOBE, HP Notifications, HP Connection Optimizer, HP Sure Click, HP Privacy Settings, HP Cloud Recovery, HP Sure Admin, HP Client Management Script Library (free download), HP BIOSphere Gen6, myHP, HP Desktop Support Utilities, HP Image Assistant Gen5 (free download), HP Easy Clean, HP Smart Support, HP Manageability Integration Kit (free download), HP Connect for Microsoft Endpoint Manager, HP Patch Assistant (free download), HP SureRun Gen5, HP Sure Recover Gen5, HP Wolf Security for Business, HP Sure Sense Gen2, HP Services Scan, HP Sure Start Gen7, HP Driver Packs (free download)
17.7 cm x 17.5 cm x 3.4 cm
1.42 kg
Environmental Standards
TCO Certified Desktops 9, ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site
Bundled with
Personal computer
Product Form Factor
Mini
Sensors
HP Tamper Lock
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Bundled with
Processor / Chipset
CPU
Clock Speed
1.6 GHz (P-core) / 1.2 GHz (E-core)
Max Turbo Speed
4.6 GHz (P-core) / 3.2 GHz (E-core)
Number of Cores
14-core
CPU Qty
1
Max CPU Qty
1
L2 cache
11.5 MB
Chipset Type
Intel Q670
Cache Memory
Installed Size
L3 Cache - 24 MB
Cache Per Processor
24 MB
RAM
Installed Size
DDR5 SDRAM
Effective Memory Speed
4800 MHz
Rated Memory Speed
4800 MHz
SO-DIMM 262-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2
1 x 256 GB
Interface Type
PCI Express
NVM Express (NVMe)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP 320K
USB
Localization & Layout
Mouse
Mouse Name
HP 125
Interface (Bus) Type
PCI Express Mini Card (M.2)
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Wi-Fi 6E AX 211
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6E), Bluetooth 5.3
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), auto-uplink (auto MDI/MDI-X), PXE 2.1 support, dual stream (2x2)
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.11d, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.3az, IEEE 802.11r, IEEE 802.11v
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x M.2 Card - 2230 (for wireless module) , 2 (total) / 1 (free) x M.2 Card - 2280 (for internal storage)
1 x headphones/microphone (CTIA and OMTP headset support) , 5 x USB 3.2 Gen 2 (2 front, 3 rear) (two of them with wake functionality, one of them is charging) , 1 x USB-C 3.2 Gen 2x2 (charging) , 2 x DisplayPort 1.4a , 1 x HDMI , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion sensor, retractable padlock loop
Security Slot Type
Kensington security slot
FCC Class B certified, ICES-003, CCC, FIPS 140-2 Level 2, RoHS, UL 60950-1, CSA C22.2 No. 60950-1-07, WEEE, KCC Class B, Common Criteria EAL4+, CECP, VCCI Class B, SEPA, low halogen, UL 62368-1, Japan PC Green Label, IEEE 1680.1, Taiwan Green Mark, Korea Eco-Label, CSA C22.2 No. 62368-1-14
Power adapter
AC 100-240 V (50/60 Hz)
Power Provided
90 watt
Efficiency
89% (230VAC), 88% (115VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 11 Pro English
Software
Sustainability Information
TCO Certified
ENERGY STAR Certified
17.7 cm
17.5 cm
3.4 cm
1.42 kg
Shipping Width
49.8 cm
Shipping Depth
13.2 cm
Shipping Height
23.5 cm
Shipping Weight
2.95 kg
10 °C
35 °C
10 - 90% (non-condensing)
Warranties (6)
HGH5 HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service In Stock £32.96
HGH5 HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £27.34
HGH5 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £34.13
HGH5 HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £69.44
HGH5 HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site In Stock £57.67
HGH5 HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site In Stock £80.03
Accessories (4)
HGH5 HP Dual VESA Sleeve v3 - Desktop sleeve for HP 260 G4 In Stock £26.75
HGH5 HP B250 Mounting Kit for LCD Display/Thin Client In Stock £34.25
HGH5 HP DM V4+ VESA Sleeve In Stock £25.69
HGH5 HP DM v4+ VESA Sleeve with Power Supply Holder In Stock £23.72
Monitors (7)
HGH5 HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £164.32
HGH5 HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £491.31
HGH5 HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £165.42
HGH5 HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor In Stock £77.18
HGH5 HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £115.80
HGH5 HP 324ph Series 3 Pro 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £82.71
HGH5 HP 524pm Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £259.17
Keyboards and Mice (5)
HGH5 HP 128 Wired Mouse In Stock £8.48
HGH5 HP 455 Programmable Keyboard - Wireless - UK In Stock £26.44
HGH5 HP 125 - Mouse - wired - USB - black In Stock £6.20
HGH5 HP Desktop 320MK - Keyboard and mouse set - full size - USB - UK - black In Stock £15.39
HGH5 HP 320K Wired Keyboard In Stock £11.78
Other bundles (43)
HGH5 HPE USB to Serial Port Adapter In Stock £13.95
HGH5 HP USB G2 Stereo Headset In Stock £20.21
HGH5 Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £208.06
HGH5 Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A In Stock £208.06
HGH5 Poly Voyager 4320 UC V4320-M C USB-A WW In Stock £108.17
HGH5 Poly Voyager 4320 UC V4320 C USB-C WW In Stock £106.60
HGH5 Poly DA85-M Sound Card In Stock £44.59
HGH5 Poly EncorePro HW520 Stereo Headset (Noise Cancelling) In Stock £65.27
HGH5 Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £43.62
HGH5 Poly Voyager 4320 UC V4320-M C USB-A CS WW In Stock £108.73
HGH5 Poly Voyager 4320 UC V4320-M C USB-C WW In Stock £108.44
HGH5 Poly Voyager 4320 UC V4320 C USB-A CS WW In Stock £117.00
HGH5 Poly Savi 7320 Office S7320 Stereo Headset In Stock £242.98
HGH5 Poly Voyager 4310 UC V4310-M C USB-A WW In Stock £98.17
HGH5 Poly Voyager 4320 UC V4320-M C USB-C CS WW In Stock £115.93
HGH5 Poly Voyager 4320 UC V4320 C USB-A WW In Stock £106.60
HGH5 Poly Voyager 4310 UC V4310 C USB-A WW In Stock £98.17
HGH5 Poly Voyager 4310 UC V4310 C USB-A CS WW In Stock £108.40
HGH5 Poly EncorePro 525 USB EP525 USB-A Headset In Stock £87.21
HGH5 Poly Voyager Focus 2 UC-M USB-C Headset with Stand In Stock £141.12
HGH5 Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £109.27
HGH5 Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified In Stock £32.44
HGH5 Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £35.37
HGH5 Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £67.04
HGH5 Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £45.04
HGH5 Poly Savi 8420 Office headset - on-ear - DECT / Bluetooth - wireless - active noise cancelling In Stock £164.89
HGH5 Poly Wireless Headset System Base for Bluetooth headset - for Poly Voyager In Stock £89.69
HGH5 HyperX Pulsefire Core Gaming Mouse In Stock £27.43
HGH5 Poly Savi 8410 Office headset - on-ear - DECT / Bluetooth - wireless - black In Stock £190.01
HGH5 Poly Blackwire 3210 headset - on-ear - wired - USB-C - black In Stock £25.87
HGH5 Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £61.00
HGH5 Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £25.93
HGH5 Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £25.27
HGH5 Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £24.80
HGH5 Poly EncorePro 515-M headset - on-ear - wired - USB-A - black In Stock £77.77
HGH5 Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams In Stock £108.17
HGH5 Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £48.40
HGH5 Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £48.57
HGH5 Poly Blackwire 3215 - headset - 3.5 mm jack, USB-C In Stock £46.27
HGH5 Poly Blackwire 5210 - headset - 3.5 mm jack, USB-C In Stock £61.00
HGH5 Poly Blackwire 3220 USB-C HS +USB-C/A Headset In Stock £26.96
HGH5 Poly Blackwire 5220 USB-C HS +USB-C/A Headset In Stock £63.33
