Intentionally crafted to deliver crisp visuals and personalized comfort, the HP E27u G5 QHD USB-C Monitor redefines flexibility and power, so there's nothing between you and your best. Stylishly designed with the planet in mind, this display is the perfect fit for both the office and home.
Ergonomic Setup Guide
Achieve all-day comfort when you apply the best practices from the Ergonomic Setup Guide. -
Enhanced Viewing Comfort with HP Eye Ease
HP Eye Ease, an always-on, low-blue light filter, helps keep your eyes comfortable throughout the day by reducing blue light without impacting color-now enhanced with a 75Hz refresh rate. -
IPS Panel
No matter where you stand, IPS technology ensures image accuracy and consistency across wide 178-degrees horizontal and vertical viewing angles. -
Daisy Chain a Second Monitor
Display even more with DisplayPort by daisy chaining a second monitor for the ultimate dual-display setup. -
99% sRGB Color Space
Ideal color reproduction with minimal effort. -
Endless Adjustability
Work effortlessly with 4-way ergonomics that help keep your neck, shoulders, and back comfortable throughout the day. Customize pivot, tilt,150 mm height adjust, and swivel settings to fit you, your desk, and your needs.
- HP E27u G5 - E-Series - LED monitor - QHD - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class F
- Power Consumption (On mode)
- 22.7 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 75 Hz
- Pixel Pitch
- 0.2335 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Haze 25%, anti-glare 3H hardness
- Voltage
- AC 100-240 V (50/60 Hz)
- Black head, black and silver (stand)
- 61.34 cm x 22.7 cm x 54.47 cm
- Localisation
- English / United Kingdom
- Works With Chromebook
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
- Carbon Footprint
- 230 kg carbon emissions
- VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, PSE Mark, cTUVus, E-Standby, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, low halogen, ICE, NRCS, Ukraine, UAE, TGM, TUV Hardware Low Blue Light Certification, Energy Star, Works With Chromebook (WWCB) certified, Korea MEPS, Ukraine EE
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2335 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 120 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese
- HDCP, On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 3 Side Borderless Design, 8-bit Colour Depth, HP Eye Ease
- 61.34 cm x 22.7 cm x 54.47 cm - with stand
- DisplayPort 1.2 (HDCP) , DisplayPort 1.2 output (HDCP) , HDMI (HDCP) , USB-C 3.2 Gen 1 (data, power up to 15W) , USB-C 3.2 Gen 1 (power up to 65W) , 2 x USB-C 3.2 Gen 1 , USB-C 3.2 Gen 1 (power only) , LAN (RJ-45)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 45
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
- 1 x USB-C to USB-C cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 22.7 W
- Power Consumption SDR (On mode)
- 22.7 kWh/1000h
- Power Consumption (Typical)
- 34.5 watt
- Power Consumption (Max)
- 160 watt
- Power Consumption Stand by
- 0.5 watt
- Included Software
- HP Display Center, HP Display Manager
- Dimensions & Weight Details
- With stand - width: 61.34 cm - depth: 22.7 cm - height: 54.47 cm , Without stand - width: 61.34 cm - depth: 4.67 cm - height: 36.46 cm
- Shipping Width
- 69.9 cm
- Shipping Depth
- 16 cm
- Shipping Height
- 44.6 cm
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
- 141
- Logistics (kg CO2e)
- 3
- Use (kg CO2e)
- 96
- EOL (kg CO2e)
- 3
- Total Carbon w/o Use Phase (kg CO2e)
- 240
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
