Uniquely designed to deliver incredible visuals and extended flexibility, the HP E27k G5 4K USB-C Monitor redefines precision, so there's nothing between you and your best. Stylishly crafted with your comfort and the planet in mind, this 4K display is a powerhouse of productivity.
Ergonomic Setup Guide
Achieve all-day comfort when you apply the best practices from the Ergonomic Setup Guide. -
HP Eye Ease
HP Eye Ease is an always-on, low-blue light filter that helps keep your eyes comfortable throughout the day by reducing blue light without impacting color accuracy or adding a yellow color shift. -
Ambient Light Sensor
Automatically adjusts your screen's brightness to the lighting of your environment for comfortable viewing. -
4K Resolution
Get lost in the captivating definition and ultra-precise details of 4K resolution. The pixel dense 3840 x 2160 resolution expands your workspace and transforms all your content into a remarkable, lifelike experience. -
IPS Panel
No matter where you stand, IPS technology ensures image accuracy and consistency across wide 178-degrees horizontal and vertical viewing angles. -
99% sRGB Color Space
Ideal color reproduction with minimal effort.
 - HP E27k G5 - E-Series - LED monitor - 27"
 - LED-backlit LCD monitor - 27"
- Energy Class
 - Class F
- Power Consumption (On mode)
 - 26.1 W
 - USB 3.2/USB-C hub, USB PD 65 Watt
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - 4K UHD (2160p) 3840 x 2160 at 60 Hz
- Pixel Pitch
 - 0.15 mm
- Brightness
 - 350 cd/m²
- Contrast Ratio
 - 1000:1 / 8000000:1 (dynamic)
- Response Time
 - 5 ms (grey-to-grey with overdrive)
- Colour Support
 - 1.07B (8-bit + FRC)
- Colour Gamut
 - 99% sRGB
- Input Connectors
 - HDMI, DisplayPort, USB-C
- Built-in Ethernet
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Haze 25%, anti-glare 3H hardness
- Voltage
 - AC 100-240 V (50/60 Hz)
 - Black head, black and silver (stand)
 - 61.34 cm x 22.73 cm x 54.7 cm
 - 7.5 kg
- Localisation
 - English / United Kingdom
- Environmental Standards
 - TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
 - CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, PSE Mark, cTUVus, E-Standby, KC, CECP, CEL, EAC, ISC, SEPA, BIS, low halogen, ICE, NRCS, Ukraine, CEL Grade 3, UAE, TGM, Energy Star, Works With Chromebook (WWCB) certified, Korea MEPS, Ukraine EE
 - 5-year warranty
- Bundled Services
 - HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
- Display Type
- Energy Class
 - Class F
- Diagonal Size
 - 27"
- Built-in Devices
 - USB 3.2/USB-C hub
- USB Power Delivery
 - 65 Watt
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.15 mm
- Pixel Per Inch
 - 163
- Brightness
 - 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
 - 99% sRGB
- Response Time
- Vertical Refresh Rate
 - 30 - 60 Hz
- Horizontal Refresh Rate
 - 30 - 135 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - Edge-lit LED
- Colour Temperature
 - 6500K
- OSD Languages
 - Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese
 - Ambient light sensor, On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 3 Side Borderless Design, HP Eye Ease, 10 bits (8 bits + FRC)
 - 61.34 cm x 22.73 cm x 54.7 cm - with stand
 - 7.5 kg
Audio
 - Speakers - stereo
- Output Power / Channel
 - 3 Watt
 - DisplayPort 1.4 (HDCP) , HDMI (HDCP) , LAN (RJ-45) , USB-C 3.2 Gen 1 (HDCP, DisplayPort Alt Mode, power up to 65W) , USB-C 3.2 Gen 1 (HDCP, power up to 15W) , 2 x USB 3.2 Gen 1 , USB 3.2 Gen 1 (power only)
Mechanical
- Tilt Angle
 - -5/+20
- Swivel Angle
 - 90
- Rotation Angle
 - -90/+90
- Height Adjustment
 - 150 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
 - 1 x USB-C to USB-C cable - 1 m
- Backlight Life
 - 30,000 hours
- Localisation
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 26.1 W
- Power Consumption SDR (On mode)
 - 26 kWh/1000h
- Power Consumption (Typical)
 - 29 Watt
- Power Consumption (Max)
 - 190 Watt
- Power Consumption Stand by
 - 0.5 Watt
- Included Software
 - HP Display Center, HP Display Manager
- Dimensions & Weight Details
 - With stand - width: 61.34 cm - depth: 22.73 cm - height: 54.7 cm - weight: 7.5 kg , Without stand - width: 61.34 cm - depth: 4.7 cm - height: 36.46 cm - weight: 5.4 kg
- Shipping Width
 - 69.9 cm
- Shipping Depth
 - 44.6 cm
- Shipping Height
 - 16 cm
- Shipping Weight
 - 10 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
 - Limited warranty - 5 years
- Bundled Services
 - 5 °C
 - 35 °C
 - 20 - 80% RH (non-condensing)
