Uniquely designed to deliver incredible visuals and extended flexibility, the HP E27k G5 4K USB-C Monitor redefines precision, so there's nothing between you and your best. Stylishly crafted with your comfort and the planet in mind, this 4K display is a powerhouse of productivity.
Ergonomic Setup Guide
Achieve all-day comfort when you apply the best practices from the Ergonomic Setup Guide. -
HP Eye Ease
HP Eye Ease is an always-on, low-blue light filter that helps keep your eyes comfortable throughout the day by reducing blue light without impacting color accuracy or adding a yellow color shift. -
Ambient Light Sensor
Automatically adjusts your screen's brightness to the lighting of your environment for comfortable viewing. -
4K Resolution
Get lost in the captivating definition and ultra-precise details of 4K resolution. The pixel dense 3840 x 2160 resolution expands your workspace and transforms all your content into a remarkable, lifelike experience. -
IPS Panel
No matter where you stand, IPS technology ensures image accuracy and consistency across wide 178-degrees horizontal and vertical viewing angles. -
99% sRGB Color Space
Ideal color reproduction with minimal effort.
- HP E27k G5 - E-Series - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class F
- Power Consumption (On mode)
- 26.1 W
- USB 3.2/USB-C hub, USB PD 65 watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.15 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Support
- 1.07B (8-bit + FRC)
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Haze 25%, anti-glare 3H hardness
- Voltage
- AC 100-240 V (50/60 Hz)
- Black head, black and silver (stand)
- 61.34 cm x 22.73 cm x 54.7 cm
- 7.5 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified
- CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, PSE Mark, cTUVus, E-Standby, KC, CECP, CEL, EAC, ISC, SEPA, BIS, low halogen, ICE, NRCS, Ukraine, CEL Grade 3, UAE, TGM, Energy Star, Works With Chromebook (WWCB) certified, Korea MEPS, Ukraine EE
- 5-year warranty
- Bundled Services
- HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.2/USB-C hub
- USB Power Delivery
- 65 watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.15 mm
- Pixel Per Inch
- 163
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 30 - 60 Hz
- Horizontal Refresh Rate
- 30 - 135 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- Edge-lit LED
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese
- Ambient light sensor, On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 3 Side Borderless Design, HP Eye Ease, 10 bits (8 bits + FRC)
- 61.34 cm x 22.73 cm x 54.7 cm - with stand
- 7.5 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 watt
- DisplayPort 1.4 (HDCP) , HDMI (HDCP) , LAN (RJ-45) , USB-C 3.2 Gen 1 (HDCP, DisplayPort Alt Mode, power up to 65W) , USB-C 3.2 Gen 1 (HDCP, power up to 15W) , 2 x USB 3.2 Gen 1 , USB 3.2 Gen 1 (power only)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- -90/+90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
- 1 x USB-C to USB-C cable - 1 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 26.1 W
- Power Consumption SDR (On mode)
- 26 kWh/1000h
- Power Consumption (Typical)
- 29 watt
- Power Consumption (Max)
- 190 watt
- Power Consumption Stand by
- 0.5 watt
- Included Software
- HP Display Center, HP Display Manager
- Dimensions & Weight Details
- With stand - width: 61.34 cm - depth: 22.73 cm - height: 54.7 cm - weight: 7.5 kg , Without stand - width: 61.34 cm - depth: 4.7 cm - height: 36.46 cm - weight: 5.4 kg
- Shipping Width
- 69.9 cm
- Shipping Depth
- 44.6 cm
- Shipping Height
- 16 cm
- Shipping Weight
- 10 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 5 years
- Bundled Services
- 5 °C
- 35 °C
- 20 - 80% RH (non-condensing)
