Inspire joy on your desk with the clean connectivity of the HP E27d G4 QHD Advanced Docking Monitor. Add your everyday accessories at the display, then add your PC with just one USB-C cable. Empower IT to remotely manage HP devices from anywhere on the network through RJ-45.
Drive your workspace from USB-C
Connect, charge, and power your PC up to 100W through one USB-C cable, then embrace the easy connectivity of additional ports like USB and RJ-45. Expand to dual displays by daisy-chaining through DisplayPort . -
Manage deployments over a network
Help IT secure and remotely manage your deployed commercial HP PCs and the display with advanced network manageability features that include PXE Boot, LAN/WLAN switching, and WoL and MAC Address Pass-Through in all power states. -
Simplify everyday tasks
Instantly turn on your display and laptop, even when the lid is closed, with a single button on the display. Login with your face and Windows Hello on the webcam with IR, or use it to videoconference.
- HP E27d G4 Advanced Docking Monitor - LED monitor - 27" - Smart Buy
- LED-backlit LCD monitor - 27"
- Energy Class
- Class F
- Energy Consumption per Year
- 43 kWh
- Power Consumption (On mode)
- 25.7 W
- 2 microphones, IR camera, USB 3.0/USB-C hub, USB PD 100 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100 - 240 V (50/60 Hz)
- Black
- 61.36 cm x 4.85 cm x 53.54 cm
- 8.2 kg
- Localisation
- English / United Kingdom
- Manufacturer Selling Program
- HP Smart Buy
- Plug and Play, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, MEPS, E-Standby, CEC, KC, CECP, EAC, CEL Grade 1, ISC, BIS, DisplayPort 1.2, DisplayPort 1.4, SmartWay, HP GSE, AUS/NZ
- 3-year warranty
- Bundled Services
- HP 5 years Next Business Day Bundled Support Extension for Monitors (United Kingdom)
- Display Type
- Energy Class
- Class F
- 43 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB Power Delivery
- 100 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 109
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Gamut
- 99% sRGB
- Response Time
- 5 ms
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, Windows 10 Hello, 8-bit Colour Depth, 99% sRGB colour gamut
- Black
- 61.36 cm x 4.85 cm x 53.54 cm - with stand
- 8.2 kg
- DisplayPort (HDCP) , DisplayPort output , HDMI (HDCP) , USB-C 3.1 Gen 1 upstream/DisplayPort Alt Mode with Power Delivery (power up to 100W) , USB-C downstream , 4 x USB 3.0 downstream , Headphone/microphone combo jack (mini-jack)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 60
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, arsenic free, mercury free
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB 3.1 Gen 2 cable - 1 m
- Backlight Life
- 30,000 hours
- Localisation
- HP Smart Buy
- Security Slot Type
- Kensington security slot
- Input Voltage
- 25.7 W
- Power Consumption SDR (On mode)
- 25.7 kWh/1000h
- Power Consumption (Typical)
- 80 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 61.36 cm - depth: 4.85 cm - height: 53.54 cm - weight: 8.2 kg , Without stand - width: 61.36 cm - depth: 4.85 cm - height: 36.6 cm - weight: 5.5 kg
- Shipping Width
- 69.6 cm
- Shipping Depth
- 27.5 cm
- Shipping Height
- 46.9 cm
- Shipping Weight
- 13.3 kg
- Limited warranty - parts and labour - 3 years
- Bundled Services
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.36 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £32.96 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £5.93 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.59 |
