Brand
HP E27d G4 27" 2560x1440 5ms HDMI DisplayPort USB-C IPS LED Advanced Docking Monitor
Quicklinx: FRPBWS00 Mfr#: 6PA56AT#ABU
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5ms
Interfaces: HDMI, USB-C, DisplayPort
£524.14 ex VAT
£628.96 inc VAT
Inspire joy on your desk with the clean connectivity of the HP E27d G4 QHD Advanced Docking Monitor. Add your everyday accessories at the display, then add your PC with just one USB-C cable. Empower IT to remotely manage HP devices from anywhere on the network through RJ-45.
  • Drive your workspace from USB-C
    Connect, charge, and power your PC up to 100W through one USB-C cable, then embrace the easy connectivity of additional ports like USB and RJ-45. Expand to dual displays by daisy-chaining through DisplayPort .
  • Manage deployments over a network
    Help IT secure and remotely manage your deployed commercial HP PCs and the display with advanced network manageability features that include PXE Boot, LAN/WLAN switching, and WoL and MAC Address Pass-Through in all power states.
  • Simplify everyday tasks
    Instantly turn on your display and laptop, even when the lid is closed, with a single button on the display. Login with your face and Windows Hello on the webcam with IR, or use it to videoconference.
HP E27d G4 Advanced Docking Monitor - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Energy Consumption per Year
43 kWh
Power Consumption (On mode)
25.7 W
2 microphones, IR camera, USB 3.0/USB-C hub, USB PD 100 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100 - 240 V (50/60 Hz)
61.36 cm x 4.85 cm x 53.54 cm
8.2 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8
Plug and Play, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, MEPS, E-Standby, CEC, KC, CECP, EAC, CEL Grade 1, ISC, BIS, DisplayPort 1.2, DisplayPort 1.4, SmartWay, HP GSE, AUS/NZ
3-year warranty
Bundled Services
HP 5 years Next Business Day Bundled Support Extension for Monitors (United Kingdom)
Display Type
Energy Class
Class F
43 kWh
Diagonal Size
27"
Built-in Devices
USB Power Delivery
100 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
300 cd/m²
Contrast Ratio
Colour Gamut
99% sRGB
Response Time
5 ms
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, Windows 10 Hello, 8-bit Colour Depth, 99% sRGB colour gamut
61.36 cm x 4.85 cm x 53.54 cm - with stand
8.2 kg
DisplayPort (HDCP) , DisplayPort output , HDMI (HDCP) , USB-C 3.1 Gen 1 upstream/DisplayPort Alt Mode with Power Delivery (power up to 100W) , USB-C downstream , 4 x USB 3.0 downstream , Headphone/microphone combo jack (mini-jack)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
60
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, arsenic free, mercury free
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB 3.1 Gen 2 cable - 1 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
25.7 W
25.7 kWh/1000h
Power Consumption (Typical)
80 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 61.36 cm - depth: 4.85 cm - height: 53.54 cm - weight: 8.2 kg , Without stand - width: 61.36 cm - depth: 4.85 cm - height: 36.6 cm - weight: 5.5 kg
Shipping Width
69.6 cm
Shipping Depth
27.5 cm
Shipping Height
46.9 cm
Shipping Weight
13.3 kg
TCO Certified
Limited warranty - parts and labour - 3 years
Bundled Services
5 °C
35 °C
20 - 80% (non-condensing)
Accessories (1)
FRPB HP B300 Mounting Bracket In Stock £32.48
Warranties (4)
FRPB HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £15.53
FRPB HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £30.10
FRPB HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £15.53
FRPB HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £6.01
Diagonal Size: 27in
Response Time: 5ms
Interfaces: HDMI
Interfaces: USB-C
Interfaces: DisplayPort
Brand: HP
Price Range Ex VAT: £500 - £750
