HP E27 G5 27" 1920x1080 5ms HDMI DisplayPort USB IPS LED Monitor
Quicklinx: J5TGWS00 Mfr#: 6N4E2AA#abu
More than 50 In Stock
£123.88 ex VAT
£148.65 inc VAT
Intentionally crafted to deliver crisp visuals, personalized comfort, and true flexibility, the HP E27 G5 FHD Monitor redefines comfort, so there's nothing between you and your best. Stylishly designed with the planet in mind, this display is the perfect fit for both the office and home.
HP E27 G5 - E-Series - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class D
Power Consumption (On mode)
17 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.3113 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort, USB
Display Position Adjustments
Screen Coating
Haze 25%, anti-glare 3H hardness
Voltage
AC 100-240 V (50/60 Hz)
Black, black and silver (stand)
61.2 cm x 22.7 cm x 54.6 cm
6.96 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Carbon Footprint
230 kg carbon emissions
VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, PSE Mark, cTUVus, E-Standby, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, low halogen, ICE, NRCS, Ukraine, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TGM, TUV Hardware Low Blue Light Certification, Energy Star, Korea MEPS
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3113 mm
Pixel Per Inch
82
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 3 Side Borderless Design, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease
61.2 cm x 22.7 cm x 54.6 cm - with stand
6.96 kg
DisplayPort 1.2 (HDCP) , HDMI (HDCP) , USB-B , 3 x USB 3.2 Gen 1 (Type A) , USB 3.2 Gen 1 (Type A (power only))
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x HDMI cable - 1.8 m , 1 x DisplayPort 1.2 cable - 1.8 m , 1 x USB-B to USB-A cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
17 W
17 kWh/1000h
Power Consumption (Typical)
30 Watt
Power Consumption (Max)
50 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Center
Dimensions & Weight Details
With stand - width: 61.2 cm - depth: 22.7 cm - height: 54.6 cm - weight: 6.96 kg , Without stand - width: 61.17 cm - depth: 4.64 cm - height: 36.33 cm - weight: 4.83 kg
Shipping Width
69.9 cm
Shipping Depth
16 cm
Shipping Height
44.6 cm
Shipping Weight
10.88 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
140
Logistics (kg CO2e)
3
Use (kg CO2e)
85
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
230
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Brand: HP
